楼主: elephant20009
IAR Embedded Workbench for ARM Version 5.41
 楼主| 发表于 2010-4-29 03:33:43 | 显示全部楼层
 楼主| 发表于 2010-4-29 03:34:58 | 显示全部楼层
IAR Embedded Workbench for ARM 5.41.1 (376 MB)
IAR Embedded Workbench with its optimizing C/C++ compiler is an integrated development environment for building and debugging ARM-based embedded applications. It provides extensive support for a wide range of ARM devices, hardware debug systems and RTOSs and generates very compact and efficient code. Ready-made device configuration files, flash loaders and over 1400 example projects are included.
 楼主| 发表于 2010-4-29 03:36:01 | 显示全部楼层
Code editor:
- Convenient user interface;
- Automatic allocation errors
- Customizable toolbar;
- Allocation directives Xi;
- Developed search engine.
 楼主| 发表于 2010-4-29 03:37:46 | 显示全部楼层
C compiler
- One of the best compilers on the effectiveness of the code;
- Fully compliant with ANSI C;
- Several models for the efficient allocation of memory;
- Algorithm optimization specifically for the AVR-microcontroller;
- Language extensions for embedded systems.
 楼主| 发表于 2010-4-29 03:38:47 | 显示全部楼层
Assembler
- Integrated Macroassembler for real-time applications;
- Includes a preprocessor for C compiler.
 楼主| 发表于 2010-4-29 03:39:48 | 显示全部楼层
Linker
- Supports full layout, placement, and the creation of format;
- Supports more than 30 standard output formats for use with in-circuit emulator;
- Loading modules only when needed;
- The output format is fully compatible with AVR Studio.
 楼主| 发表于 2010-4-29 03:40:59 | 显示全部楼层
Simulator and debugger
- Debugging in C and assembler code;
- Multiple breakpoints;
- Language descriptions of peripheral and input / output operations;
- Viewing area CODE, DATA, EEPROM registers and I / O;
- Handling interrupts with the prediction;
- Control of any variables and stack;
- Complex data types.
 楼主| 发表于 2010-4-29 03:42:05 | 显示全部楼层
Supported kernels:
- ARM7 (ARM7TDMI, ARM7TDMI-S, ARM720T);
- ARM7E (ARM7EJ-S);
- ARM9 (ARM9TDMI, ARM920T, ARM922T, ARM940T);
- ARM9E (ARM926EJ-S, ARM946E-S, ARM966E-S, ARM968E-S);
- ARM10E (ARM1020E, ARM1022E);
- ARM11;
- SecurCore (SC100, SC110, SC200, SC210);
- Cortex-M1;
- Cortex-M3;
- Cortex-R4;
- Cortex-M0;
- XScale.
 楼主| 发表于 2010-4-29 03:43:13 | 显示全部楼层
 楼主| 发表于 2010-4-29 03:44:17 | 显示全部楼层
GMT+8, 2025-12-11 08:52 , Processed in 0.018818 second(s), 3 queries , Gzip On, Redis On.
