楼主: elephant20009
QuartusII 9.1
 楼主| 发表于 2010-4-27 04:16:30 | 显示全部楼层
 楼主| 发表于 2010-4-27 04:17:54 | 显示全部楼层
 楼主| 发表于 2010-4-27 04:18:57 | 显示全部楼层
Quartus II Software v9.1 Service Pack 2
Requires Quartus II software version 9.1
    * Additional programming support (POF) for the Cyclone IV GX and E, Arria II GX, Stratix IV GT and E devices
    * Includes final timing models for additional Stratix IV E, GX and GT devices
    * Support for the new CPRI intellectual property core
    * Includes additional software enhancements
https://www.altera.com/support/s ... artus_index_new.jsp
 楼主| 发表于 2010-4-27 04:20:06 | 显示全部楼层
Nios II Embedded Design Suite Version 9.1 Service Pack 2   New Version ButtonGo Button
Requires Quartus? II software version 9.1 and the Nios II Embedded Design Suite version 9.1
    * Additional device support for Cyclone? IV GX and E, Arria II GX, Stratix IV GT and E
    * Contains fixes for an issue for customers using the Altera Vectored Interrupt Controller (VIC) along with the Nios II Enhanced Interrupt Controller (EIC) port provided in the ACDS 9.1 release. This issue does not affect users who are using the (default) Nios II internal interrupt controller.
You must update Quartus II software version 9.1 to service pack 2 to use the Nios II Embedded Design Suite version 9.1 service pack 2.
https://www.altera.com/support/s ... /upd-nios_index.jsp
 楼主| 发表于 2010-4-27 04:21:25 | 显示全部楼层
 楼主| 发表于 2010-4-27 04:22:26 | 显示全部楼层
Use Quartus_II_9.1_SP2_x86.exe to crack files sys_cpt.dll and quartus.exe under C:\altera\91\quartus\bin folder.
Replace the XXXXXXXXXXXX in the license.dat with your own MAC address (the MAC address could be found at Quartus II 9.1 main screen->Tools->License Setup, the NIC ID is your MAC)
Navigate to  Quartus II 9.1 main screen->Tools->License Setup, and then select the license.dat, don't forget to click OK when you finish the setting.
Note: the license.dat should be stored in the path which contains no space and no non-English characters.
        This path had been verified under Windows XP and Windows 7 both 32bit and 64 bit version.
        Study purpose only.
 楼主| 发表于 2010-4-27 04:23:41 | 显示全部楼层
Altera Quartus NIOS II Embedded Design Suite v9.1 incl SP2 Windows-SHooTERS | 590Mb
Nios II Software Build Tools—a set of powerful commands, utilities, and scripts to manage build options for applications, board support packages, and software libraries.
Nios II Software Build Tools For Eclipse—a fully integrated development environment built from the ground up using Nios II Software Build Tools as a foundation built entirely as plug-ins to industry-standard Eclipse.
Nios II Software Build Tools for Eclipse focuses on improving software productivity for large software applications and team-based software design.
Key features:
* Faster software compile times as compared to Nios II IDE
* Fine control over build options for board support packages
* Improved revision control and project hand off
* Feature-rich Nios II Flash Programmer GUI for building composite flash images
The new Nios II Software Build Tools for Eclipse is part of the Nios II Embedded Design Suite and is the next generation of the Nios II IDE. The Nios II IDE will continue to ship as a legacy tool. You can find instructions on converting your Nios II IDE project to the new Nios II Software Build Tools for Eclipse in the Appendix A. Using the Nios II Integrated Development Environment (PDF).
 楼主| 发表于 2010-4-27 04:25:04 | 显示全部楼层
 楼主| 发表于 2010-4-27 04:26:33 | 显示全部楼层
 楼主| 发表于 2010-4-27 04:27:39 | 显示全部楼层
GMT+8, 2025-12-30 06:42 , Processed in 0.023285 second(s), 3 queries , Gzip On, Redis On.
