楼主: chungcy5
ncverilog : window version 软件下载
 楼主| 发表于 2010-4-29 12:16:24 | 显示全部楼层
please download
发表于 2010-5-9 12:25:35 | 显示全部楼层
我要down 了
发表于 2010-6-26 00:57:46 | 显示全部楼层
Is it complete?
发表于 2010-6-26 01:10:33 | 显示全部楼层
Try it!
发表于 2010-6-26 01:16:10 | 显示全部楼层
1. execute LDV50/setup.exe
2. install "Cadence License Manager" first
3. When finish to install "Cadence license Manager",
   copy Crack/cds.dat to C:\Program Files\Cadence Design Systems\Cadence License Manager
   and modify the cds.dat file.
   (SERVER PCNAME ANY 5280 => PCNAME = ivan-879541d50b from 我的電腦, pc名稱)
4. execute LDV50/setup.exe
5. install "LDV Software" => install NC-Sim
6. When screen show "Configure License server information" window,
   key in "5280@PCNAME" => PCNAME = ivan-879541d50b from 我的電腦, pc名稱)
7. execute start => Cadence License Manager FLEXlm Toolkit (Lmtools)
   => refer the file Crack/ncsim.jpg to set "Config Service"
   (data in C:\Program Files\Cadence Design Systems\Cadence License Manager\)=> "Save Service"
8. execute start => Cadence License Manager FLEXlm Toolkit (Lmtools)
   => Start/Stop/reread => Start Server
发表于 2010-6-26 01:19:25 | 显示全部楼层
WINDOWS INSTALLATION AND LICENSING
INSTALLATION
Perform the following procedures to install Cadence products on Windows.
1. Insert the CD into the CD-ROM drive.
   The installation main menu should pop up on the screen.
   If autorun is disabled and the installation main menu does not
   show up on the screen, browse to the CDROM directory and
   double click on setup.exe to start the installation.
2. Click on an appropriate product family name to install products.
   Install and configure the Cadence License Manager only on the machine
   that will be the license server.
3. Answer the prompts of the installation program, and proceed as directed.
LICENSING
Perform the following procedures to configure the licensing of Cadence
1. Open the "LMTOOLS" using Start->Programs->Cadence License Manager->FlexLm
   toolkits(Lmtools)
2. Click the "Config Services" tab.
   Enter Service Name (for example, LDV50).
   Then ensure that the proper paths are set for lmgrd.exe, the license file, and
   the Debug Log File.
   Save the service using Save Service button.
   Click the Save Service button to save the service.
   Note : To restart the license server automatically when you reboot your machine,
   click on "Use Services".
3. Click on the "Start/Stop/Reread" tab window.
   Click on "Start Server" to start the server. The license manager
   should start.
   To stop the license manager, click "Stop Server".
4. Click the "Server Status" tab.
   To check the status of the license manager, click "Perform Status Enquiry".
发表于 2010-6-26 01:22:51 | 显示全部楼层
1.安裝過程中 Configure License Server Information 填  5280@xxxx  xxxx=自己電腦名稱
2.修改csd.dat檔的第一行   SERVER server ANY 5280
                                 ^^^^^^改成自己電腦名稱
3.設定License Manager(執行C:\Program Files\Cadence Design Systems\Cadence License Manager\lmtools.exe)
  看圖ncsim.jpg設定
发表于 2010-7-2 00:30:10 | 显示全部楼层
thank you
发表于 2010-7-2 06:04:50 | 显示全部楼层
感謝無私分享
发表于 2010-7-2 11:07:07 | 显示全部楼层
thanks X ~~
GMT+8, 2025-12-19 18:32 , Processed in 0.020604 second(s), 4 queries , Gzip On, Redis On.
