查看: 2622|回复: 0
高薪诚聘IC设计工程师 (在深圳市内工作)
发表于 2006-8-25 10:26:30 | 显示全部楼层 |阅读模式
健康的创业团队诚邀设计工程师加盟(2名), 条件如下
Mixed-signal IC Design Engineer
MSEE, Ph.D. preferred, minimum 2 years of analog/mixed signal IC design experience. The candidate must have strong analog and mixed-signal electronics background and a solid understanding of analog building blocks, such as on-chip oscillator, bandgap, comparator, programmable current DAC, charge pump etc.; silicon proven design is a plus. Experience in circuit implementation, layout, and debugging; familiar with CAD tools (Pspice, Hspice etc.); basic knowledge of the semiconductor process is a plus.
System Application Engineer
BS/MS in electrical engineering (or equivalent) and two years of relevant experience are typically required. The candidate is expected to have a strong technical background in digital design and a strong knowledge of system level debugging; experience with PCB and schematic design tools, verilog/VHDL, C and assembly language. Experience with PWM/timer, programmable state machine & serial communication interface design is a plus. Good oral/written communication skills to effectively engage in the different R&D areas and with customers; self-motivated with the ability to work under pressure.
有意者敬请联络 梁先生 chris6998@126.com; 来信必复.
GMT+8, 2025-12-13 23:09 , Processed in 0.016809 second(s), 10 queries , Gzip On, Redis On.
