Job Description:
Successful candidate has at least three to five years of switch mode power supply design experience in PFC, and forward or double switch forward or LLC topology in high power (>100W and <1000W) , high volume, cost critical applications, in PC or Server or Workstation or IPC Power Company will be added scores to this candidate.
The FAE has responsibility to provide customer technical support to XX-TW’s DD (direct design) accounts and XX-TW’s direct accounts and 58 Disti accounts in Greater China Team. The FAE should be able to provide XX solution with design report and/or proto board to customer. The FAE will work in close cooperation with the XX Taiwan Sales and FAE of DD and direct accounts and disties, and interface directly with XX Applications Engineering in San Jose, California.
The successful candidate must be capable of performing first line technical support at circuit level. The FAE will perform critical measurements for correlation with the XX Applications Team in U.S.A. The successful candidate will also attend 1-2 annual technical meetings at PI's U.S.A. factory headquarters. English ability needs to be okay to communicate with XX-HQ in US.
Education (state minimum requirement): BSEE or equivalent.
Experience (state minimum requirement):
Minimum two years of Switch Mode Power Supply Design Experience.Position requires extensive travel throughout Taiwan including 1-2 annual FAE Engineering meetings at the U.S.A. headquarters. Basic English reading, writing and speaking.
KT Human Resources Consulting Company (Shanghai) was established in 2001 in response to a need for a recruitment consultancy to be an active, contributing member of the semiconductor community, as opposed to simply a supplier to it.We provide professional search and talent acquisition in the Integrated Circuit、Electronic、Telecommunications industry of international corporations in Greater China. Our client list contains numerous international companies, many of them are long-term customers.
If you interested in the job, pls sent your cv to: hr@kthr.com, thanks! |
