查看: 4526|回复: 0
求助(急)
发表于 2006-8-12 16:12:29 | 显示全部楼层 |阅读模式
今天用proteus作了一个数字温度计仿真
仿真的时候出现这样的错误提示
SIMULATION LOG
Design:   C:\Documents and Settings\angle\My Documents\proteus\mine\数字温度计\sensior.DSN
Doc. no.: <NONE>
Revision: <NONE>
Author:   <NONE>
Created:  06/08/02
Modified: 06/08/12
Compiling source files...
Build completed OK.
Compiling netlist...
Linking netlist...
WARNING [LINKER] : Unresolved module pin 'U3_ON1'.
WARNING [LINKER] : Unresolved module pin 'U3_ON2'.
WARNING [LINKER] : Unresolved module pin 'U4_ON1'.
WARNING [LINKER] : Unresolved module pin 'U4_ON2'.
WARNING [LINKER] : Unresolved module pin 'U5_ON1'.
WARNING [LINKER] : Unresolved module pin 'U5_ON2'.
Partition analysis...
ERROR [PSM] : No model specified for 'RV1'.
ERROR [PSM] : No model specified for 'U1'.
ERROR [PSM] : No model specified for 'U2'.
Simulation FAILED due to partition analysis error(s).
其中的U1是adc0804
           U2是温度传感器lm45
         U3,U4,U5 是三个反相运算放大器
有谁知道是怎么回事儿?
能不能帮忙解释一下?
GMT+8, 2025-12-30 05:10 , Processed in 0.016496 second(s), 7 queries , Gzip On, Redis On.
