楼主: linux2k
Any torrents for SOC Encounter?
 楼主| 发表于 2009-12-3 23:26:12 | 显示全部楼层
All files have now been extracted. I ran ./patch_encounter on the directory. It made a new directory in KITS. But to to run the program? Making a iso of the directory and running setup.sh fails! Please post install instructions.
发表于 2009-12-4 21:28:30 | 显示全部楼层
[url = http://www.eetop.cn/bbs/redirect.php?goto=findpost&pid=3202035&ptid=220944] 11 # [/ url] linux2k [/ i] [/ b]
download all the links,put in one folder of KITS and then extract manaually.
SOC81Base:
Base_S0C08.10.000_lnx86_1of3.tar
http://www.damipan.com/file/3HTGLhU.html
Base_S0C08.10.000_lnx86_2of3.tar
http://www.damipan.com/file/3HWGr0a.html
Base_S0C08.10.000_lnx86_3of3.tar
http://www.damipan.com/file/3HZWSJR.html
 楼主| 发表于 2009-12-6 09:12:17 | 显示全部楼层
After i installed (by running setup.sh), installscape is started. I pointed it to the dir of the extracted file then went through the install process.  My target install folder now has 2.2GB of files, but where is encounter?
发表于 2009-12-7 11:25:18 | 显示全部楼层
13# linux2k
dont run  setup.sh file go to KITS folder extract, in linux you type WHICH ENCOUNTER
u get the path
 楼主| 发表于 2009-12-8 08:33:43 | 显示全部楼层
Okay, all file sin kit have been extracted. There are now several folders. There is a folder called bin, in this there is encounter. But it cannot be executed. It is a dangling symbolic link and the permission cannot be changed. Where exactly is the encounter executable?  "which encounter" does not work.
发表于 2009-12-8 14:11:58 | 显示全部楼层
[url = http://www.eetop.cn/bbs/redirect.php?goto=findpost&;pid=3227767&ptid=220944] 15 # [/ url] linux2k [/ i] [/ b]
In that .cshrc file give ur tool path,license path.
In linux mode
1)csh
2)source .cshrc
3)encounter
发表于 2009-12-15 00:10:38 | 显示全部楼层
good work
发表于 2009-12-15 08:00:20 | 显示全部楼层
It is working???????
发表于 2009-12-15 08:04:59 | 显示全部楼层
very bigggggg...
发表于 2009-12-15 10:25:28 | 显示全部楼层
楼上提供的种子文件是可用的吗?
GMT+8, 2025-12-21 19:39 , Processed in 0.020701 second(s), 5 queries , Gzip On, Redis On.
