楼主: muchong5997
Cadence 背景的修改
发表于 2014-5-12 22:04:09 | 显示全部楼层
转发一个官方的支持方法。http://www.edaboard.com/thread174506.html
1- run icfb
2- Open a Terminal and type:
xrdb -query > xyz
3- return to specified folder. You should see the xyz file. Open this file in edit mode.
4- in the xyz file, change or add the option Opus.editorBackground from
black to your desired one. for example:
Opus.editorBackground: white
5- at the UNIX or LINUX prompt (e.g. the second terminal you opened), type:
xrdb -load xyz
6- restart your Cadence software
7- Enjoy the result!
发表于 2014-8-9 13:13:05 | 显示全部楼层
仿真的波形是可以改的,好像是在graphic下有个选项
GMT+8, 2025-12-21 15:01 , Processed in 0.017015 second(s), 3 queries , Gzip On, Redis On.
