楼主: Ansel
IE3D 下载
发表于 2009-9-18 10:14:40 | 显示全部楼层
What version of your IE3D
What version of your IE3D, please tell us before we download them?
IE3D 14.1, please visit the following website
http://www.eetop.cn/bbs/thread-188372-1-1.html
IE3D 14.1 Announcement
We are pleased to announce the release of IE3D EM Design System Version 14.1. IE3D V14 was a huge leap forward from IE3D V12. IE3D V14.1 is further improved from IE3D V14.
The major implementations on IE3D V14.1 compared to IE3D V14 are:
(1)
Full implementation of OpenMP multi-CPU support for the major processes of IE3D full-wave simulation engine. For most structures, the V14.1 engine can be more than twice as fast as the V14 engine on a quad-core computer.
(2)
Further improved GUI to simplify the layout editing and visualization.
(3)
Implementation of non-isotropic metallic types for more accurate and efficient modeling of pin via arrays in modeling RFIC structures.
(4)
Implementation of advanced simulation algorithm for accurate modeling of thick metal with multi-fold simulation speed improvement.
(5)
Implementation of model simplification by removing small polygons and slots required in 45-nm CMOS processes in AGIF.
IE3D V14 features:
(1)
Complete EM design environment with integrated layout editing, full-wave EM simulation, real-time EM tuning and optimization, s-parameters, current distribution, near field and radiation pattern visualization and post-processing.
(2)
Implementation of text objects for better documentations of designs.
(3)
Much improved layout editing with easy access and control of geometry objects, and options to speed up geometry editing of large structures.
(4)
Implementation of Boolean operations for connecting arbitrary 3D objects for high accuracy and easy geometry modeling.
(5)
Modeling of surface roughness.
(6)
Wide frequency s-parameter extraction covering from 1 Hz to 10 THz.
(7)
Coupled ports and differential ports de-embedding in highly packed circuits.
(8)
Improved multi-CPU support and significantly improved simulation speed on Windows 64.
(9)
Further improved layout editing on IE3DLibrary for Boolean driven, equation-based geometry modeling with easy parameterization, access and control of objects.
(10)
Automatic creation of IE3D/AGIF templates from TSMC unified technology files for automated layout creation and batch IE3D EM simulations from GDSII files.
发表于 2010-3-28 00:36:54 | 显示全部楼层
有软件吗?
发表于 2010-3-28 01:56:24 | 显示全部楼层
能用来仿真硅基片上螺旋电感吗?
发表于 2010-5-30 23:34:19 | 显示全部楼层
分数不够....
发表于 2010-5-31 12:51:12 | 显示全部楼层
支持一下吧,谢谢楼主~~~~~~~
发表于 2010-6-1 21:35:49 | 显示全部楼层
thank you
发表于 2010-6-13 20:27:02 | 显示全部楼层
thank you
发表于 2010-6-13 23:42:29 | 显示全部楼层
哪个版本的
发表于 2010-9-23 11:39:00 | 显示全部楼层
有专业版???
发表于 2010-9-23 11:43:34 | 显示全部楼层
GMT+8, 2025-11-8 03:16 , Processed in 0.018394 second(s), 3 queries , Gzip On, Redis On.
