查看: 42593|回复: 162
Cadence SoC Encounter 8.1 (Rapidshare)
发表于 2009-9-9 01:08:00 | 显示全部楼层 |阅读模式
With the Cadence® SoC Encounter™ RTL-to-GDSII System, engineers can account for the effects of interconnect across the entire chip—from the outset of the implementation cycle. It combines RTL synthesis, silicon virtual prototyping, automated floorplan synthesis, clock network synthesis, design for manufacturability and yield, low-power and mixed-signal design support, and nanometer routing. It also offers the latest capabilities to support advanced 65nm and 45nm designs.
Features/Benefits
    * Supports multiple implementation styles with built-in power-planning, floorplanning, and signal integrity analysis
    * Supports multiple methodologies for flip-chip implementation, promoting concurrent chip/package design
    * Provides a statistical static timing analysis solution and standardized ECSM library models
    * Incorporates cutting-edge yield and low-power design capabilities
    * Handles 50M+ gate designs at 90nm and below
I reuploaded the correct image. Old files are removed.
Download:
http://rapidshare.com/files/325425951/Cadence_SoC_Encounter_8.1.7z.001
http://rapidshare.com/files/325399690/Cadence_SoC_Encounter_8.1.7z.002
http://rapidshare.com/files/325393089/Cadence_SoC_Encounter_8.1.7z.003
http://rapidshare.com/files/325407773/Cadence_SoC_Encounter_8.1.7z.004
http://rapidshare.com/files/325395283/Cadence_SoC_Encounter_8.1.7z.005
http://rapidshare.com/files/325433511/Cadence_SoC_Encounter_8.1.7z.006
http://rapidshare.com/files/325481170/Cadence_SoC_Encounter_8.1.7z.007
http://rapidshare.com/files/325401356/Cadence_SoC_Encounter_8.1.7z.008
http://rapidshare.com/files/325409273/Cadence_SoC_Encounter_8.1.7z.009
http://rapidshare.com/files/325430013/Cadence_SoC_Encounter_8.1.7z.010
http://rapidshare.com/files/325461547/Cadence_SoC_Encounter_8.1.7z.011
http://rapidshare.com/files/325464861/Cadence_SoC_Encounter_8.1.7z.012
http://rapidshare.com/files/325455779/Cadence_SoC_Encounter_8.1.7z.013
http://rapidshare.com/files/325540023/Cadence_SoC_Encounter_8.1.7z.014
http://rapidshare.com/files/325466965/Cadence_SoC_Encounter_8.1.7z.015
http://rapidshare.com/files/325471544/Cadence_SoC_Encounter_8.1.7z.016
http://rapidshare.com/files/325475343/Cadence_SoC_Encounter_8.1.7z.017
http://rapidshare.com/files/325483554/Cadence_SoC_Encounter_8.1.7z.018
http://rapidshare.com/files/325506887/Cadence_SoC_Encounter_8.1.7z.019
http://rapidshare.com/files/325500858/Cadence_SoC_Encounter_8.1.7z.020
http://rapidshare.com/files/325512054/Cadence_SoC_Encounter_8.1.7z.021
http://rapidshare.com/files/325528108/Cadence_SoC_Encounter_8.1.7z.022
http://rapidshare.com/files/325520799/Cadence_SoC_Encounter_8.1.7z.023
http://rapidshare.com/files/325539321/Cadence_SoC_Encounter_8.1.7z.024
http://rapidshare.com/files/325531564/Cadence_SoC_Encounter_8.1.7z.025
http://rapidshare.com/files/325524429/Cadence_SoC_Encounter_8.1.7z.026
http://rapidshare.com/files/325527652/Cadence_SoC_Encounter_8.1.7z.027
http://rapidshare.com/files/325536269/Cadence_SoC_Encounter_8.1.7z.028
http://rapidshare.com/files/325540232/Cadence_SoC_Encounter_8.1.7z.029
http://rapidshare.com/files/325373481/Cadence_SoC_Encounter_8.1.7z.030
Password:
mj
发表于 2009-9-9 06:49:38 | 显示全部楼层
Thanks!!!
发表于 2009-9-9 08:16:22 | 显示全部楼层
顶你!
发表于 2009-9-9 08:16:30 | 显示全部楼层
有没有update
发表于 2009-9-10 05:22:54 | 显示全部楼层
how can i combine these files?
发表于 2009-9-10 13:31:56 | 显示全部楼层
Thanks
Thanks a lot
发表于 2009-9-10 16:43:53 | 显示全部楼层
Thanks!!
发表于 2009-9-11 07:58:57 | 显示全部楼层
好东西,一定要顶的!
[ 本帖最后由 lwwlww 于 2009-9-11 08:07 编辑 ]
发表于 2009-9-11 13:00:36 | 显示全部楼层
7zip压缩的有问题,解压后文件名都错了!
发表于 2009-9-11 15:04:10 | 显示全部楼层
需要用hjsplit合并文件
嘿嘿
谁把它下载完,然后传到纳米盘?
GMT+8, 2025-12-29 12:43 , Processed in 0.026199 second(s), 7 queries , Gzip On, Redis On.
