查看: 9876|回复: 11
求助变压器transformer模型
发表于 2009-8-27 11:35:00 | 显示全部楼层 |阅读模式
三绕组变压器transformer
能够在cadence下spectre仿真的模型
等效电路或veriloga模型均可啊
求助急用啊,哪位帮忙指点一下
发表于 2009-9-1 21:13:49 | 显示全部楼层
关注,学习下
发表于 2010-8-31 13:17:43 | 显示全部楼层
hspice 可以转陈?
发表于 2013-2-19 14:06:28 | 显示全部楼层
any one help of it ?!
发表于 2013-2-22 18:00:21 | 显示全部楼层
学习了 谢谢
发表于 2013-5-22 17:36:02 | 显示全部楼层
回复 1# feiyufox
之前大牛贴的,我只是帮忙转一下,不是原创!
转发请记得说下,尊重原作者!
    // VerilogA for edaboard, transformer, veriloga
`include "constants.vams"
`include "disciplines.vams"
module transformer(pr1,pr2,sec1,sec2,th1,th2);
inout pr1,pr2,sec1,sec2,th1,th2;
electrical pr1,pr2,sec1,sec2,th1,th2;
parameter real n1 = 1.0 from [1:inf); //number of turns in primary winding
parameter real n2 = 3.0 from [1:inf); //number of turns in second winding
parameter real n3 = 3.0 from [1:inf); //number of turnes in third winding
parameter real L = 1n from (0:inf); //inductanse per one turn in H
parameter real k12 = 0.97 from [0:1]; //coupling between first and second, first and third windings
parameter real R1 = 1.0 from [0:inf); //resistance of primary winding in Ohm
parameter real R2 = 3.0 from [0:inf); //resistance of second winding in Ohm
parameter real R3 = 3.0 from [0:inf); //resistance of third winding in Ohm
real k13,F1,F2,F3;
analog begin
@(initial_step or initial_step("dc")) begin
k13 = k12;
end
F1 = L*(n1*I(pr1,pr2)-k12*n2*I(sec1,sec2)-k13*n3*I(th1,th2)); //magnetic flow through primary winding
F2 = L*(n2*I(sec1,sec2)-k12*n1*I(pr1,pr2)+n3*I(th1,th2)); //magnetic flow through secondary winding
F3 = L*(n3*I(th1,th2)-k13*n1*I(pr1,pr2)+n2*I(sec1,sec2)); //magnetic flow through secondary winding
V(pr1,pr2)<+R1*I(pr1,pr2)+n1*ddt(F1);
V(sec1,sec2)<+R2*I(sec1,sec2)+n2*ddt(F2);
V(th1,th2)<+R3*I(th1,th2)+n3*ddt(F3);
end
endmodule
发表于 2013-6-14 15:05:49 | 显示全部楼层
good 谢谢了
发表于 2013-6-14 15:06:29 | 显示全部楼层
谢谢了 good
发表于 2013-6-30 19:03:13 | 显示全部楼层
很需要
謝謝了
发表于 2014-3-5 08:46:59 | 显示全部楼层
回复 9# jalong
    this veriloga model sim
1. input sin
2. input pwm pulse
zoom out find
veriloga 可模擬 flyback transformer 漏感嗎???
GMT+8, 2025-12-29 02:27 , Processed in 0.023345 second(s), 6 queries , Gzip On, Redis On.
