查看: 2179|回复: 0
ethmac simulation failed
发表于 2009-8-9 12:00:02 | 显示全部楼层 |阅读模式
从opencores网址下载的最新版本的ethmac,用ncsim做simulation的时候,tb_eth.log中有一些报"FAILED"的case,
比如:
At time:              8991769
Test: TEST 10: SLIDING STOP SCAN COMMAND IMMEDIATELY AFTER WRITE
REQUEST ( WITH AND WITHOUT PREAMBLE )
*FAILED* because
Data was not correctly written into OR read from PHY register -
control register
Heading: MAC HALF DUPLEX FLOW TEST
At time:            483196167
    Test: TEST 0: DEFER, COLL. AND LATE COLL. WHILE TRANSMITTING AND
RECEIVING FRM. AT 4 TX/RX BD ( 10Mbps )
    *FAILED* because
    Transmit should NOT start more than 1 CLK after CarrierSense and
causing Collision
At time:            484976407
    Test: TEST 1: DEFER, COLL. AND LATE COLL. WHILE TRANSMITTING AND
RECEIVING FRM. AT 4 TX/RX BD ( 100Mbps )
    *FAILED* because
causing Collision
At time:            955522987
    *FAILED* because
causing Collision
请问有人碰过同样或类似的问题吗?是RTL本身的bug还是有的设置我没设好,导致的failed?
请高手的指点,谢谢!
GMT+8, 2025-12-4 10:10 , Processed in 0.053809 second(s), 8 queries , Gzip On, Redis On.
