最近搜集了一些国内外研究平面天线方向的论文,
主要都是手机天线,UWB天线,平面天线方向的,
需要的兄弟尽管下载,
支持的话就给个回复,
对我来说也是一种鼓励,呵呵
65M 12个压缩包
下面是目录:
hand effect
1. Tunable planar inverted-F antenna using rf MEMS switch for the reduction of human hand effect
2. Designing ground plane to reduce hand effects on mobile handsets
3. User's hand effects on EMC internal GSM/DCS mobile phone antenna
4. Feeding point determination regarding hand effect of PIFA for mobile RFID band
5. Some experimental results for the head/hand effects in personal communications
6. Some experimental results for the head/hand effects in personal communications(??? ??)
7. A Compact Wideband Planar Diversity Antenna Covering UMTS and 2.4 GHz WLAN Bands
8. Automatic antenna tuning for RF transmitter IC applying high Q antenna
9. Performance of a Multiband Diversity Antenna with Hand Effects
10. Internal Patch Antenna With a Thin Air-Layer Substrate for GSM/DCS Operation in a PDA Phone
11. Internal Compact Dual-Band Printed Loop Antenna for Mobile Phone Application
12. An analysis of the performance of a handsetdiversity antenna influenced by head, hand, and shoulder effects at 900MHz .II. Correlation characteristics
13. An analysis of the performance of a handsetdiversity antenna influenced by head, hand, and shoulder effects at 900MHz .I. Effective gain characteristics
14. Exploiting the Effects of Human Hands on theRadiation Characteristics for the Implementation of Self-adaptive FeedCircuit of Offset-fed Slot Antennas in Parallel for the Reception of Digital Terrestrial TV Broadcasting
15. Design of a 900/1800 MHz dual-band loop antenna mounted on a handset considering the human hand and head effects
intenna
16. Feeding point determination for PIFA type mobile phone handset internal antenna
17. Theoretical study of angular distribution ofplane waves in a small reverberation chamber for simulating multipathenvironment and testing mobile phones
internal antenna
18. A mobile antenna study of radiation efficiency in human head and hand environment
19. Radiation Pattern of a 2.4/ 5.2GHz Laptop Internal Antenna: Near Field Spherical Range Measurements and Full Wave Analysis
20. Feeding point determination for PIFA type mobile phone handset internal antenna
21. Investigation of SAR of an internal antenna of mobile phones
22. A dual-band internal antenna with a parasiticpatch for mobile handsets and the consideration of the handset case andbattery
23. A wideband internal antenna with dual monopole radiation elements
24. Hepta-Band Internal Antenna for Personal Communication Handsets
25. A New Compact Hexaband Internal Antenna of the Planar Inverted F-Type for Mobile Handsets
26. Design of a Compact Internal Antenna for Multi-Band Personal Communication Handsets
27. Design of a novel multiband internal antenna for personal communication handsets
28. Dual-band internal antenna of PIFA type for mobile handsets and the effect of the handset case and battery
29. A triple-band internal antenna for mobile hand-held terminals
30. A new enhanced-bandwidth internal antenna for portable communication systems
31. A Simple PIFA-Based Tunable Internal Antenna for Personal Communication Handsets
32. Study and design of a capacitively coupled polymeric internal antenna
33. Design of a multiband internal antenna for third generation mobile phone handsets
34. A triple-band internal antenna: design and performance in presence of the handset case, battery, and human head
35. TDMB/AMPS/GSM/DCS/PCS/SDMB internal antenna using parasitic element with switching circuit
36. Multiband internal antenna for mobile phones
37. A compact internal antenna for wireless USB dongle application
38. Design of a multi-band internal antenna using an open stub
39. A miniature wideband internal antenna with dual resonant structures
40. A Quad-Band Internal Antenna Having Independent Controllability of Low/High Resonant Frequencies
41. Compact internal antenna using a ferrite material for DVB-H reception in mobile phones
42. Design of an ultra-wideband internal antenna using symmetrical radiators for mobile application
43. Broadband internal antenna of planar monopole type for mobile handsets
44. Multi-band internal antenna including DVB-H band
45. A dual-band internal antenna of PIFA type for bluetooth/WLAN in mobile handsets
46. Internal antenna for multiband mobile handset applications
47. Triple band internal antenna using matching circuits
48. Triple band internal antenna with a novel feeding structure
49. The effects of the handset case, battery, and human head on the performance of a triple-band internal antenna
50. Planar inverted-F antenna with a hollow shorting cylinder for internal mobile phone antenna
51. Bandwidth and radiation properties of internal handset antennas
52. Progress of multi-band antenna technology in mobile phone industry
53. Multiband Printed Monopole Slot Antenna for WWAN Operation in the Laptop Computer
54. Internal GSM/DCS antenna backed by a step-shaped ground plane for a PDA phone
55. Internal Ultrawideband Monopole Antenna for Wireless USB Dongle Applications
56. New compact six-band internal antenna
57. Uni-Planar Dual-Band Monopole Antenna for 2.4/5 GHz WLAN Operation in the Laptop Computer
58. Multiband antenna with parasitic branches for laptop applications
59. Internal antenna with modified monopole type for DVB-H applications
60. Small internal antennas for indoor UMTS base station with WLAN access point
61. Shorted Monopole Dual Band Antenna for Ultra-Thin Profile Slider Mobile Phone
62. Compact Five Band Internal Antenna for Mobile Phone
63. Radio and antenna integration for mobile platforms
64. Internal antenna for UHF-band mobile RFID system
65. Monopole antenna fed by a coaxial cable in slide phone for GSM/DCS/PCS operation
66. A compact quad-band PIFA by using defected ground structure
67. Designing ground plane to reduce hand effects on mobile handsets
68. Folded planar monopole internal antenna for multi-band mobile phones
69. A design of wide band small chip antenna using the branch structure for mobile phone
70. A design of miniaturized built-in penta band chip antenna for EGSM/GPS/DCS/USPCS/WCDMA Mobile Handset
71. An embedded tri-band planar inverted-F antenna with a branch-line shorting strip
72. The folded inverted conformal antenna (FICA) for multi-band cellular phones
73. Meandered planar inverted-F antenna for PCS mobile phone
74. New type of small broad-band internal antenna for third generation mobile phone handsets
75. Metal-plate shorted T-shaped monopole for internal laptop antenna for 2.4/5 GHz WLAN operation
76. Dual and wide band internal planar antenna for wireless LAN
77. A design of an antenna for KPCS/IMT-2000 dual-band applications
78. Small Antennas for Hyperthermia
79. Slot Antennas With an Extended Ground for Multiple-Antenna Systems in Compact Wireless Device
80. A Compact Tunable Internal Antenna for Personal Communication Handsets
81. Design of a planar inverted-F Antenna with very wide impedance bandwidth
82. A broadband interior antenna of planar monopole type in handsets
83. Printed Loop Antenna With a Perpendicular Feed for Penta-Band Mobile Phone Application
84. Dual-band planar inverted F antenna for GSM/DCS mobile phones
85. GSM/DCS/IMT-2000 triple-band built-in antenna for wireless terminals
86. EMC internal patch antenna for UMTS operation in a mobile device
87. Dual-band flat-plate antenna with a shorted parasitic element for laptop applications
88. Radio frequency electromagnetic fields in largeconducting enclosures: effects of apertures and human bodies onpropagation and field-statistics
89. Internal Compact Dual-Band Printed Loop Antenna for Mobile Phone Application
90. Octa-band internal monopole antenna for mobile phone applications
91. Design concept of multi-band antenna with resonant circuit on PCB
92. Novel internal multi-antenna configuration employing folded dipole elements for notebook PC
enjoy it。。。。
下载页面
http://www.eetop.cn/bbs/thread-180103-1-1.html
[ 本帖最后由 tianxian 于 2009-7-15 12:54 编辑 ] |
