查看: 2998|回复: 7
GPS New Book GPS & Galileo : Dual RF Front-end receiver and Design
发表于 2009-5-8 12:40:32 | 显示全部楼层 |阅读模式
Product Description
Design State-of-the-Art GPS/Galileo Dual RF Receivers This authoritative guide walks you through the process of designing, fabricating, and testing a highly integrated, low-noise, low-power, and low-cost RF front-end for GPS and Galileo, the leading satellite-based global navigation systems. Everything from standards analysis to characterization of the design is covered in the book. GPS & Galileo focuses on developing seamlessly interoperable receivers that can access the wide variety of new services offered by these systems, such as increased service availability, centimeter-sensitive accuracy, emergency management, and data confidentiality. By the end of the book, you will have a prototype that achieves peak performance in terms of gain, NF, and current consumption, making it suitable for any high-accuracy, portable application. Discover how to: Determine the specifications of an interoperable dual GPS/Galileo RF front-end Design all RFIC blocks, including the receiver chain, PLL, control logic, and PADs Select the required external components Implement optimal floor planning Perform validation testing of the integrated RF front-end Understand real-world fields of application Gauge the performance of the front-end within a receiver linked to a full-solution platform
Detail see http://www.eetop.cn/bbs/viewthread.php?tid=167611&page=1&extra=page%3D1#pid2235892
发表于 2010-2-10 15:33:44 | 显示全部楼层
支持一下
发表于 2010-10-6 23:04:13 | 显示全部楼层
大力支持一下!!
发表于 2010-11-12 21:31:26 | 显示全部楼层
感谢楼主!!!!!!!
发表于 2010-11-14 23:11:40 | 显示全部楼层
this is a great book.!
发表于 2011-7-3 17:44:11 | 显示全部楼层
发表于 2014-2-15 23:00:37 | 显示全部楼层
感谢分享
发表于 2016-5-5 17:31:15 | 显示全部楼层
thanks!
GMT+8, 2025-12-16 03:52 , Processed in 0.021970 second(s), 7 queries , Gzip On, Redis On.
