楼主: xuyanyan141
RFIC新人,小女请教
发表于 2009-6-3 07:37:32 | 显示全部楼层
some useful books for RFIC design
There are some useful books for RFIC design.
1.Analysis and design of analog integrated circuit, by Gray
2.Analysis and design of CMOS radio frequency integrated circuit, by Lee
3.RF microelectronics, by Razavi
You can study the basic analog circuit theory (current mirror,single stage amplifier,multi-stage amplifier,frequency response,electronics noise) with the first book.Then you can learn the high frequency design technique (S-parameter,Smith chart) and the RF blocks (LNA,mixer,VCO,PA) with the second book. Finally, you can learn the transceiver topology and the communication theory with the third book.
发表于 2009-6-16 12:54:10 | 显示全部楼层
很多
发表于 2009-6-16 22:09:31 | 显示全部楼层
还需要基本的半导体器件知识。Try Sze's Semiconductor book.
可能微波原理也很有用。Need the knowledge of S-parameter, impedance matching.
发表于 2009-6-16 23:37:00 | 显示全部楼层
还是先把微波理论好好学习一下吧,感觉这个还是很重要的,工作后就没有什么机会了。
 楼主| 发表于 2009-6-22 11:36:47 | 显示全部楼层
谢谢各位!非常感谢!
发表于 2009-6-23 13:29:37 | 显示全部楼层
There are some useful books for RFIC design.$ u% g$ Q- Z& _9 t, z
1.Analysis and design of analog integrated circuit, by Gray5 e7 F& V+ \$ C: T% _& z3 g; l' Q# m
2.Analysis and design of CMOS radio frequency integrated circuit, by Lee3 {6 Q" S1 i, O) R6 K
4 H0 M4 \, ?& F+ @0 F; Z' J9 ?/ K; I5 T; J# J, y" S4 t8 i
You can study the basic analog circuit theory (current mirror,singlestage amplifier,multi-stage amplifier,frequency response,electronicsnoise) with the first book.Then you can learn the high frequency designtechnique (S-parameter,Smith chart) and the RF blocks(LNA,mixer,VCO,PA) with the second book. Finally, you can learn thetransceiver topology and the communication theory with the third book.
thanks.
发表于 2009-7-12 11:30:18 | 显示全部楼层
同楼主一样 受教了~~
发表于 2009-7-14 19:10:29 | 显示全部楼层
学射频 当然少不了  看 微波技术基础
搞无线电 不就是 电磁波的应用技术吗?
发表于 2009-8-15 11:58:07 | 显示全部楼层
Lee的那本书挺不错的~可以看看
发表于 2009-8-19 05:56:08 | 显示全部楼层
RF and analog design
GMT+8, 2025-12-24 21:21 , Processed in 0.018676 second(s), 5 queries , Gzip On, Redis On.
