发表于 2012-12-5 13:42:12
显示全部楼层
回复 1# xinsh
。。求助啊!!opencore上的Tri-mode_Ethernet_Specification上说明如下:
Before you start to use this IP core, you need to make your working
enviroment ready. At fist, you need to install WIN2K operation
system(recommend) or other stable operation system.In addtion, Cygwin is
needed to run some bash scripts.Tcl/tk is also needed for many GUI scripts.
Finally, the cadence LDV nc-sim is needed for simualtion. If you are using
worksation, you need Tcl/tk of your platform for GUI scripts and LDV nc-sim. I
recommend WIN2K + Cygwin0528 + LDV5.0 +Tcl/tk.
LDV5.0装在windows下面么?不懂啊。。菜鸟求助!!!
Config optaional modules
There are three optional modules can be removed frome IP core to reduce
area. You can start a GUI configuration tools to customize this IP core. Type the
following command in root directory to run a tcl/tk script.
#vish start.tcl
这个怎么run啊,vish是什么命令啊?求助!!!
有跑出来的么?请教啊!!!
qq:875995132
email:littlelijia@126.com |
