查看: 3733|回复: 1
DSP Builder安装问题,高手帮帮忙啦......
发表于 2008-12-21 00:28:36 | 显示全部楼层 |阅读模式
安装完DSP Builder之后,在Matlab中输入cd D:\altera\dspbuilder\Altlib和setup_dspbuilder.就出现了下面的情况了:
>> setup_dspbuilder
DSP Builder Version 7.0 setup
The existing file ./contents.m has been saved to ./contents.m.bak. Generating a new one...
Checking for Altera MegaCore function updates...
Warning: Unable to load model file 'D:\altera\dspbuilder\Altlib\MegaCoreAltr.mdl'.  Run "bdclose all; set_param(0, 'CharacterEncoding', Enc)" where Enc is one of windows-1252, ISO-8859-1, then load the model.  The first character that is not supported in the current character encoding setting ('ibm-1386_P100-2002') occurs on line 30, byte offset 22. To correctly load models with non-ASCII characters, you must explicitly use the character encoding that was used to save the file.  Type "help slCharacterEncoding" for more information on setting character encoding and to learn more about which encodings are commonly found on your platform.
> In load_system at 18
  In setup_megacore>megacorealtr_process_library_folder at 111
  In setup_megacore at 69
  In setup_dspbuilder at 37
Error using ==> load_system
There is no system named 'MegaCoreAltr' to open.
Warning: Unable to load model file 'D:\altera\dspbuilder\Altlib\MegaCoreAltrVIP.mdl'.  Run "bdclose all; set_param(0, 'CharacterEncoding', Enc)" where Enc is one of windows-1252, ISO-8859-1, then load the model.  The first character that is not supported in the current character encoding setting ('ibm-1386_P100-2002') occurs on line 30, byte offset 22. To correctly load models with non-ASCII characters, you must explicitly use the character encoding that was used to save the file.  Type "help slCharacterEncoding" for more information on setting character encoding and to learn more about which encodings are commonly found on your platform.
  In setup_megacore at 74
There is no system named 'MegaCoreAltrVIP' to open.
Altera MegaCore function setup completed.
DSP Builder Version 7.0 setup completed.
在Matlab的Simulink库中有Altera DSP Builder这个标题,就是没有它的元件哦......
各位英雄豪杰帮帮忙啦!
头像被屏蔽
发表于 2008-12-21 20:35:30 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-12-29 13:08 , Processed in 0.028943 second(s), 8 queries , Gzip On, Redis On.
