查看: 3169|回复: 8
PCI clock
发表于 2005-7-13 17:37:08 | 显示全部楼层 |阅读模式
请问大虾们一个问题PCI clock是方波还是正弦波?谢谢
发表于 2005-7-14 10:55:38 | 显示全部楼层
PCI clock
方波,建议你拿个显波器观察
 楼主| 发表于 2005-7-14 12:57:23 | 显示全部楼层
PCI clock
哦,谢谢
发表于 2005-7-22 13:38:57 | 显示全部楼层
PCI clock
It really depends on the equipment you use to observe the clock waveform.
If your oscilliscope is 100MHz+, then it is quite possible for you to observe a sine wave. If it is around 50MHz, then it is possible to get a square wave.
A good oscilliscope will be able to show you the quality of the clock. If you see a pure sine wave, then congratualtions, you have a good oscillator and probably a good clock buffer.
If you see some funny distortion, like mountain shape, or even tilt mountain shape, too bad, your clock suffers from a jitter or a phase problem.
In logic analyzer, it always show up as a square waveform..
发表于 2006-11-23 12:07:35 | 显示全部楼层
没看明白啊!!oscilliscope是啥?
发表于 2007-3-22 13:09:37 | 显示全部楼层
oscilliscope  是不是示波器啊
发表于 2007-5-2 01:31:10 | 显示全部楼层
對啦~是方波啦~
发表于 2007-5-2 01:32:33 | 显示全部楼层
Oh....another question...
发表于 2007-5-2 01:35:37 | 显示全部楼层
Oh...another question....what is distortion mean??? And if I have a good scope,why the pci clock show me sine wave?? So....Isn't it mean the pci clock is sine wave..??
GMT+8, 2025-9-18 04:21 , Processed in 0.019886 second(s), 6 queries , Gzip On, Redis On.
