查看: 2258|回复: 4
Electronic Correlation Mapping: From Finite to Extended Systems
发表于 2008-6-17 23:10:22 | 显示全部楼层 |阅读模式
By Jamal Berakdar
Publisher: Wiley-VCH
Number Of Pages: 205
Publication Date: 2006-03-31
ISBN-10 / ASIN: 3527403507
ISBN-13 / EAN: 9783527403509
Binding: Hardcover
An up-to-date selection of applications of correlation spectroscopy, in particular as far as the mapping of properties of correlated many-body systems is concerned.
The book starts with a qualitative analysis of the outcome of the two-particle correlation spectroscopy of localized and delocalized electronic systems as they occur in atoms and solids. The second chapter addresses how spin-dependent interactions can be imaged by means of correlation spectroscopy, both in spin-polarized and extended systems. A further chapter discusses possible pathways for the production of interacting two-particle continuum states.
After presenting some established ways of quantifying electronic correlations and pointing out the relationship to correlation spectroscopy, the author addresses in a separate chapter the electron-electron interaction in extended systems, and illustrates the ideas by some applications to fullerenes and metal clusters. The last two chapters are devoted to the investigation of the potential of two-particle spectroscopy in studying ordered surfaces and disordered samples.
Throughout the book the material is analyzed using rather qualitative arguments, and the results of more sophisticated theories serve the purpose of endorsing the suggested physical scenarios. The foundations of some of these theories have been presented in a corresponding volume entitled "Concepts of Highly Excited Electronic Systems" (3-527-40335-3).
Electronic Correlation Mapping_From Finite to Extended Systems_Wiley-VCH.2006.03.part2.rar
3.09 MB, 下载次数: 10 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-6-17 23:14:00 | 显示全部楼层
part1!!!!!!!!!!!!1
part2 under the pic
Electronic Correlation Mapping_From Finite to Extended Systems_Wiley-VCH.2006.03.part1.rar
4.39 MB, 下载次数: 10 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2008-7-1 09:45:33 | 显示全部楼层
thanks
发表于 2008-7-1 09:46:55 | 显示全部楼层
thanks
发表于 2008-7-2 07:40:15 | 显示全部楼层
Thank you very much!!
GMT+8, 2025-12-22 08:28 , Processed in 0.016054 second(s), 5 queries , Gzip On, Redis On.
