查看: 4495|回复: 8
[原创] McBSP模块配置为LCD12864的SPI接口
发表于 2008-5-22 22:29:52 | 显示全部楼层 |阅读模式
void LcdObj:cdSpiSetup(void)
#if (ccsdebug == 0)
  硬件McBSP模块配置为SPI接口
实验目的:
  演练硬件McBSP模块配置为SPI接口的应用。
  McBSP1->SPSA = SPCR1;
  McBSP1->SPSD = 0;
//  McBSP1->SPSD &= ~(1 << SPCR1_RRST);//禁止串口接收
  _delay_loop_(1);//延时等待
  McBSP1->SPSA = SPCR2;
  McBSP1->SPSD = 0;
//  McBSP1->SPSD &= ~(1 << SPCR2_XRST);//禁止串口发送
  McBSP1->SPSD = (0x02 << SPCR1_CLKSTP);//CLKSTP=10b
  McBSP1->SPSA = PCR;
  McBSP1->SPSD = (1 << PCR_FSXM)  //设置FSX引脚为输出,控制LCD12864的片选信号SS
               | (0 << PCR_FSXP)  //FSX引脚平时输出低电平(LCD12864的片选信号SS无效)
               | (1 << PCR_CLKXM) //设置CLKX引脚为输出
               | (1 << PCR_CLKXP);//CLKXP引脚平时输出高电平
  McBSP1->SPSA = SRGR1;
  McBSP1->SPSD = (0x07 << SRGR1_FWID)   //0x00~0x07~0xff
               | (0x80 << SRGR1_CLKGDV);//速率0x80
  McBSP1->SPSA = SRGR2;
  McBSP1->SPSD = (1 << SRGR2_CLKSM);//
  McBSP1->SPSA = RCR1;
  McBSP1->SPSD = (0x00 << RCR1_RFRLEN1);//8BIT
  McBSP1->SPSA = XCR1;//延时等待
  McBSP1->SPSD = (0x00 << XCR1_RFRLEN1);//8BIT
  McBSP1->SPSA = RCR2;
  McBSP1->SPSD = (0x02 << RCR2_RDATDLY);//0x01
  McBSP1->SPSA = XCR2;
  McBSP1->SPSD = (0x02 << XCR2_RDATDLY);//0x01
  McBSP1->SPSD |= (1 << SPCR2_GRST) | (1 << SPCR2_XRST) | (1 << SPCR2_FRST);
#else
  硬件McBSP模块配置为普通IO软件模拟SPI时序
实验目的:
  演练硬件McBSP模块配置为普通IO的应用.以备IO紧缺时急用。
  McBSP1->SPSD = 0;
  McBSP1->SPSD = 0;
  McBSP1->SPSA = PCR;
  McBSP1->SPSD = (1 << PCR_XIOEN) | (1 << PCR_RIOEN);//设置收发为IO接口,DX输出,DR,CLKS输入
  McBSP1->SPSD |= (1 << PCR_FSXM) | (1 << PCR_CLKXM);//设置FSX,CLKX可做IO输出
  McBSP1->SPSD |= (1 << PCR_FSRM) | (1 << PCR_CLKRM);//设置FSR,CLKR可做IO输出
  McBSP1->SPSD &= ~(1 << PCR_FSXP);//FSX信号=0
  McBSP1->SPSD |= (1 << PCR_CLKXP);//CLKX信号=1
  McBSP1->SPSD |= (1 << PCR_DX_STAT);//DX信号=1
#endif
void LcdObj:cdSend(unsigned char cData)
  cData &= 0xff;
#if (ccsdebug == 0)
  McBSP1->DXR1 = cData;//发送串行数据或命令
  while((McBSP1->SPSD & (1 << SPCR2_XRDY)) == 0) {//等待发送结束
    __nop();
    __nop();
#else
unsigned int i;
  McBSP1->SPSA = PCR;
  for (i = 0; i < 8; i ++) {
    McBSP1->SPSD &= ~(1 << PCR_CLKXP);//CLKX信号=0
    if (cData & 0x80) {//MSB最高位为1时
else {
      McBSP1->SPSD &= ~(1 << PCR_DX_STAT);//DX信号=0
cData <<= 1;
#endif
发表于 2008-5-30 12:34:36 | 显示全部楼层
支持!不错!
发表于 2008-5-31 02:50:07 | 显示全部楼层
Why not use SPI directly? (If you are programming on 2812)
发表于 2008-12-12 14:59:46 | 显示全部楼层
不错,得到了经验!
发表于 2009-2-11 19:56:12 | 显示全部楼层
xiexie
发表于 2010-1-2 11:48:47 | 显示全部楼层
THANKS
发表于 2010-1-2 15:29:55 | 显示全部楼层
不错,得到了经验!
 楼主| 发表于 2011-5-7 00:46:07 | 显示全部楼层
哈哈,好久不来了~~~
发表于 2011-6-25 20:58:42 | 显示全部楼层
不错,得到了经验!
GMT+8, 2025-12-30 22:11 , Processed in 0.029479 second(s), 7 queries , Gzip On, Redis On.
