查看: 5820|回复: 21
通信方面一些基础理论的参考文献
发表于 2008-5-2 09:02:01 | 显示全部楼层 |阅读模式
通信方面一些基础理论的参考文献都是一些较基础的理论,当然也是最重要的理论
·C. E. Shannon, “A Mathematical Theory of Communication”, Bell System Technical Journal, Vol. 27, pp. 379–423, 623–656, July, October, 1948.
·C. E. Shannon, “Communication in the Presence of Noise”, Proceeding of the IRE, vol. 37, no.1, pp. 10–21, Jan. 1949..
·J. Mark Steber, “PSK Demodulation”, Watkins-Johnson Company, Vol. 11 No. 2 March/April 1984
·M. Campanella, G. Garbo, G. Mamola and E. Randazzo, "Optimum Bandwidth-Distance Performance in Full Response CPM Systems" pp 1110-1118, IEEE Trans. on Comm. Vol. 36, N'o 10.Oct. 1988.
·S. Shepherd, J. Oniss, and S. Barton, “Asymptotic Limits in Peak Envelope Power Reduction by Redundant Coding in Orthogonal Frequency-Division Multiplex Modulation,” IEEE Trans. Commun, vol. 46, pp. 5-10, Jan. 1998.
·Siavash M. Alamouti, “A Simple Transmit Diversity Technique for Wireless Communications”, IEEE Journal on select areas in communications, Vol. 16, No. 8, October 1998.
·Joseph Mitola, III, “Software Radio Architecture: A Mathematical Perspective”, IEEE Journal on selected areas in communication, Vol. 17, No. 4, April 1999
·Arogyaswami j. Paulraj, Dhananjay A. Gore,” Analysis and Optimization of the Performance of OFDM on Frequency-Selective Time-Selective Fading Channels”, IEEE Transactions on Communications, Vol. 47, No. 12, December 1999.
·V. Tarokh and H. Jafarkhani, “A differential detection scheme for transmit diversity,” J. Sel. Area Comm., vol. 46, pp. 1169–1174, July 2000..
·V. Tarokh, H. Jafarkhani, "On the Computation and Reduction of the Peak-to-Average Power Ratio in Multicarrier Communications", IEEE rans. Comm. Vol. 48, No.1, pp. 37-44, January 2000.
·A. Soltanian and R. E. Van Dyck, “Performance of the Bluetooth system in fading dispersive channels and interference,” in Proc. IEEE Global Telecommun. Conf., Nov. 2001, pp. 3499–3503.
·A. Abdi and M. Kaveh, “A space-time correlation model for multielement antenna systems in mobile fading channels,” IEEE J. Select. Areas Commun., vol. 20, pp. 550–561, Apr. 2002.
·N. Al-Dhahir, “Overview and comparison of equalization schemes for space-time-coded signals with application to EDGE,” IEEE Trans. Signal Processing, vol. 50, pp. 2477–2488, Oct. 2002.
·S. Catreux, V. Erceg, D. Gesbert, and R. W. Heath, “Adaptive modulation and MIMO coding for broadband wireless data networks,” IEEE Commun. Mag., vol. 40, pp. 108–115, June 2002.
·C. Chuah, D. Tse, J. Kahn, and R. Valenzuela, “Capacity scaling in MIMO wireless systems under correlated fading,” IEEE Trans. Inform.Theory, vol. 48, pp. 637–650, Mar. 2002.
·N. Jindal, S. Vishwanath, and A. Goldsmith, “On the duality of Gaussian multiple-access and broadcast channels,” in Proc. Int. Symp. Inform. Theory, June 2002, p. 500.
·A. F. Molisch, M. Stienbauer, M. Toeltsch, E. Bonek, and R. S. Thoma, “Capacity of MIMO systems based on measured wireless channels,” IEEE J. Select. Areas Commun., vol. 20, pp. 561–569, Apr. 2002.
·B. Lu, X. Wang, and Y. Li, “Iterative receivers for space-time block coded OFDM systems in dispersive fading channels,” IEEE Trans.Wireless Commun., vol. 1, pp. 213–225, Apr. 2002.
·A.; Jafar, S.A.; Jindal, N.; Vishwanath, S Goldsmith.; “Capacity limits of MIMO channels” , IEEE Journal on selected areas in communications, Vol. 21, No. 5, June 2003
·B. Hassibi and B. Hochwald, “How much training is needed in multiple-antenna wireless links?,” IEEE Trans. Inform. Theory, vol. 49, pp. 951–963, Apr. 2003.
·A. Conti, D. Dardari, G. Pasolini, and O. Andrisano, “Bluetooth and IEEE 802.11b coexistence: Analytical performance evaluation in fading channels,” IEEE J. Sel. Areas Commun., vol. 21, no. 2, pp. 259–269, Feb.2003.
·Steve C Thompson, Ahsen U. Ahmed, John G. Proakis and James R. Zeidler, "Constant Envelope OFDM Phase Modulation: Spectral Containment Signal Space Properties and Performance", IEEE VfILCOM 2004, Monterey, CA.
·Lutz Lampe, Robert Schober, and Mani Jain, “Noncoherent Sequence Detection Receiver for Bluetooth Systems” IEEE Journal on selected areas in communications“ Vol. 23, No. 9, September 2005
1. A Mathematical Theory of Communication.pdf
357.71 KB, 下载次数: 25 , 下载积分: 资产 -2 信元, 下载支出 2 信元
2. Communication in the Presence of Noise.pdf
293.91 KB, 下载次数: 21 , 下载积分: 资产 -2 信元, 下载支出 2 信元
3. Certain Topics in Telegraph Transmission Theory.pdf
629.85 KB, 下载次数: 16 , 下载积分: 资产 -2 信元, 下载支出 2 信元
4. A Method for the Construction of Minimum-Redundancy Codes.pdf
323.87 KB, 下载次数: 10 , 下载积分: 资产 -2 信元, 下载支出 2 信元
5. PSK Demodulation (Part 1).pdf
95.32 KB, 下载次数: 20 , 下载积分: 资产 -2 信元, 下载支出 2 信元
6. A Simple Transmit Diversity Technique for Wireless Communications- S. Alamouti.pdf
219.95 KB, 下载次数: 23 , 下载积分: 资产 -2 信元, 下载支出 2 信元
7. Software Radio Architecture A Mathematical Perspective.pdf
458.69 KB, 下载次数: 24 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_15486202a455a79638b09b67c1c6c0d1.pdf
211.6 KB, 下载次数: 15 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_df5edf8392044dd9c3656669c26746a7.pdf
1.07 MB, 下载次数: 16 , 下载积分: 资产 -2 信元, 下载支出 2 信元
10. How much training is needed in multiple-antenna wireless links.PDF
832.94 KB, 下载次数: 13 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-10-1 13:25:14 | 显示全部楼层
真好 啊
谢谢楼主了啊   你真好
发表于 2008-10-1 14:37:46 | 显示全部楼层
xiexie
我已经下了    确实是好东西  谢谢楼主啊
发表于 2008-10-2 19:21:48 | 显示全部楼层
3q
发表于 2008-10-2 19:22:46 | 显示全部楼层
qqq
发表于 2008-11-17 16:49:14 | 显示全部楼层
好东东
发表于 2008-11-24 15:01:05 | 显示全部楼层
楼主发的都是好东西
发表于 2008-11-24 15:07:25 | 显示全部楼层
发表于 2008-11-26 10:56:20 | 显示全部楼层
谢谢楼主!
发表于 2008-11-26 11:12:51 | 显示全部楼层
谢谢楼主了~~~
GMT+8, 2025-12-24 17:59 , Processed in 0.069121 second(s), 10 queries , Gzip On, Redis On.
