查看: 2309|回复: 0
求教
发表于 2008-4-8 12:16:16 | 显示全部楼层 |阅读模式
悬赏10资产未解决
file:///C:/DOCUME~1/liuchang/LOCALS~1/Temp/msohtmlclip1/01/clip_image002.gif
Which is the physical state of a MOS transistor which is switched on?
²
Accumulation
²
Cut-off
²
Strong inversion
Statement i): The small signal output resistance of a MOS transistor decreases with increasing bias current.
Statement ii): An Operating Point analysis (OP) is not requirement to determine the small signal AC gain of a circuit.
Which of the following is correct?
²
Statement i) is true; Statement ii) is true.
²
Statement i) is true; Statement ii) is false.
²
Statement i) is false; Statement ii) is true.
²
Statement i) is false; Statement ii) is false.
Statement (i) the output resistance of an ideal current source is expected to be very small (almost zero).
Statement (ii) An N-input CMOS encompasses N+2 transistors.
²
Statement (i) is true & Statement (ii) is true
²
Statement (i) is true & Statement (ii) is false
²
Statement (i) is false & Statement (ii) is true
²
Statement (i) is false & Statement (ii) is false
GMT+8, 2025-12-20 18:37 , Processed in 0.016374 second(s), 6 queries , Gzip On, Redis On.
