查看: 98|回复: 0
求primesimPro 和 Primesim_SPICE
发表于 6 小时前 | 显示全部楼层 |阅读模式
悬赏1000资产未解决
IC231 load 了snpsSimADE 环境,一直没找到Primesim_PRO 和 Primesim_SPICE 的安装包,谁提供一下?
==== snpsSimADE Interface, X-2025.06 BUILD (05/22/2025 17:28:31) ====
  ==== COPYRIGHT 2008-2025 SYNOPSYS INC.                        ====
  snpsSimADE: Loading context at '/data/apps/cadence/IC231/tools/dfII/src/artist/snpsSimADE/snpsSimADE.ile'
  snpsSimADE: Register HSPICE ...
  snpsSimADE: use HSPICE at '/data/apps/synopsys/hspice/X-2025.06/hspice/bin/hspice'
  snpsSimADE: HSPICE Version X-2025.06 linux64 (May 22 2025 9830940)
  snpsSimADE: Register FineSim ...
*Error*   Failed to load snpsSimADE interface. Please fix the warning/error and then restart.
  snpsSimADE: Register PrimeSim_XA ...
  snpsSimADE: use xa at '/data/apps/synopsys/xa/X-2025.06-SP1/bin/xa'
  snpsSimADE: PrimeSim (TM) XA Version X-2025.06-SP1 for linux64 - Aug 27, 2025 20:10:42 10069962
  snpsSimADE: Register PrimeSim_SPICE ...
  snpsSimADE: Register PrimeSim_Pro ...
另外finesim 安装了,不过老是loading error, ADE 环境倒是能用finesim仿真,这个估计是环境设置问题,那位大侠能提供解答、
fine sim 配置如下
setenv FINESIM_HOME /data/apps/synopsys/finesim/X-2025.06
#setenv FINESIM_HOME /data/apps/synopsys/finesim/W-2024.09-SP1-1
source $FINESIM_HOME/finesim.cshrc
GMT+8, 2025-12-26 21:06 , Processed in 0.011273 second(s), 4 queries , Gzip On, Redis On.
