在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 803|回复: 3
Altair S-CALC, S-CONCRETE, S-FOUNDATION 2023 and Other S-Packages 2023
发表于 2023-9-30 02:07:06 | 显示全部楼层 |阅读模式
Altair S-CALC, S-CONCRETE, S-FOUNDATION, S-FRAME, S-STEEL, S-LINE, S-PAD, S-VIEW and S-TIMBER 2023
S-CALC 2023
S-CALC is a comprehensive section property calculator . Ideal for sections having complex geometry and multiple materials, S-CALC calculates over 16 distinct section properties. Generate cross-section properties using different calculation methods: database values, closed-form solutions, FEA methods and more. Easily define models in S- CALC's graphical editor or import geometry, material and section property data from AutoCAD® DXF and Revit® files. Produce detailed engineering reports that include all section properties, geometry, material and graphics..
S-CONCRETE 2023
Design and detail reinforced concrete to regional design codes, viewing immediate results as geometry and reinforcement parameters change. Design a single concrete column, beam, or wall, or simultaneously thousands of concrete sections at once, producing comprehensive design reports that include results for every section .
S-FOUNDATION 2023
Design, analyze and detail foundations with S-FOUNDATION. S-FOUNDATION automatically generates and manages the underlying structural FEA model as you create the foundations. Analyze with a linear or non-linear analysis, followed by a design code assessment to produce detailed engineering reports . Easily merge the foundation substructure model with the S-FRAME Analysis superstructure model for further evaluation.
S-FRAME and S-STEEL 2023
Structural analysis (S-FRAME) with integrated steel design (S-STEEL) and integrated concrete design (ICD) enables structural engineers to model and perform linear and advanced non-linear analysis for building and non-building structures. Design steel and concrete structural elements to meet regional code requirements, generate design reports, and calculate advanced section properties for non-standard sections.
S-LINE 2023
Use S-LINE to Analyze, Design and Detail reinforced multi-span continuous beams having different section dimensions and reinforcement layout for each span. S-LINE's versatility allows code checking, auto-design and detailing to multiple design codes for a variety of section types . Design and Detail Interior, Exterior, Simple Span and Cantilever beams for short and long-term deflection, flexure, shear, and torsion throughout the entire beam length.
S-PAD 2023
Use S-PAD to quickly code check a structural steel column, beam or brace without modeling the entire structure. Simply input design loads and effective lengths of the steel member then run a quick check in seconds, or even better, run an auto-design to identify the optimum section. S-PAD includes advanced code checking capabilities as well as auto-design for both strength and serviceability. This standalone application employs a simple spreadsheet-like interface that delivers powerful steel design and code check capabilities.
S-VIEW 2023
Use S-VIEW to render your model with more realistic object representation and view its analysis results. Study your structure's response by animating the results, capture good quality images of your model or results, and record an animation of the structure's response and export it as a video for presentation purposes. S-VIEW's free version makes it easy for sharing models and their results with project stakeholders and design peer review.
S-TIMBER 2023
Hybrid timber structural analysis with integrated mass timber design solution enabling structural engineers to simulate hybrid timber structures constructed from mass timber, steel, and concrete. Design mass timber members to regional design code requirements and generate design reports.
For more information about these packages, please contact   fast.forever24@gmail.com
发表于 2023-9-30 05:59:51 | 显示全部楼层
thanks
发表于 2023-9-30 08:22:21 | 显示全部楼层
发表于 2024-5-9 03:49:11 | 显示全部楼层
非常尊重你的工作。我們正在等待新產品。
GMT+8, 2024-5-20 07:31 , Processed in 0.019400 second(s), 7 queries , Gzip On, Redis On.
