查看: 7693|回复: 17
Mentor Tanner Tools 2019.2 Build 13862 x64
发表于 2020-6-11 02:02:46 | 显示全部楼层 |阅读模式
悬赏10资产未解决
Mentor Tanner Tools 2019.2 Build 13862 x64Description
Tanner Tools is a complete suite of tools for designing, simulating and inspecting electronic integrated circuits (IC) and MEMSs. This product is actually a complete product line for circuit schematic design, layout design, and inspection of integrated and analog circuits and MEMS devices. Graphic Designer Mentor is one of the leading technology companies in the field of automation for the design of electronic and semiconductor circuits. This set includes complete tools for electronic circuit design that can do all the work of circuit design, SPICE simulation, physical circuit design ( or chip layout) as well as checking circuit design rules such as DRC and LVS. There are three tools used for this process, one being S-edit for circuit schematic design, the T-SPICE circuit simulator engine integrated with S-edit,and finally L-edit for physical circuit design or printed circuit board case. Used.
Tanner EDA Tools has an unprecedented reputation for high performance and affordability for designing, layout, analogue or composite signal (AMS) verification, as well as IoT and MEMS devices. The tools in this set are simple to design and easy to learn for users. Its user interface is highly usable and the UI design team has made every effort to maintain its beauty while also increasing product usability. The processing speed of this product is high and has good compatibility with various hardware and software systems. It does not require heavy hardware and can be set up with minimal hardware.
Download Link-mega upload link.zip (179 Bytes , 下载次数: 171 ) :
发表于 2020-6-11 20:57:11 | 显示全部楼层
thansk
发表于 2020-6-11 21:00:26 | 显示全部楼层
连不上,轻转过吧
发表于 2020-6-12 01:24:46 | 显示全部楼层
尝试下载。谢谢
发表于 2020-6-12 10:51:03 | 显示全部楼层
网页都打不开,你发它做什么?
发表于 2020-6-12 13:58:35 | 显示全部楼层
Thanks!~
发表于 2020-6-12 14:30:49 | 显示全部楼层
Thank you.
发表于 2020-6-13 10:00:22 | 显示全部楼层
Need password, thx.
发表于 2020-6-13 10:23:44 | 显示全部楼层
学习需要
发表于 2020-6-13 12:15:46 | 显示全部楼层
拿走不谢,记住这个网站,这里有不少好东西,论坛里很多EDA软件这里都有
https://downloadly.ir/software/e ... d/tanner-eda-tools/
GMT+8, 2025-12-14 22:37 , Processed in 0.020605 second(s), 4 queries , Gzip On, Redis On.
