在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 1285|回复: 1
[求助] verdi 创建temporate flow view 失败
发表于 2020-1-3 17:15:48 | 显示全部楼层 |阅读模式
hello,在verdi中想要创建: Tools --> create temporate flow view上,弹出如下警告,请问去哪里更改这个变量呢?
1>Warning: cannot find signal 'ADD_X2.CLK' in FSDB , signal 'ADD_X2.CLK' will be treated as no transition (or NF)
(It may cause incorrect timing when tracing fanin cone)The possible reason is:Case of signal name does not match between FSDB and the design.
Turn on the env. variable WAVE_CASE_INSESITIVE might solve the problem.(在哪里更改这个变量的值呢?)
2>The signal 'ADD_X2.CLK' is not expandable at time 999960000. (请问下这个原因是什么?)
The driver is an input port.
3>Failed to open the flow view.
发表于 2020-1-5 21:52:51 | 显示全部楼层
1、bash或者csh的bashrc cshrc
2、找不到多个时钟的最小公倍数。
GMT+8, 2024-4-27 12:06 , Processed in 0.020643 second(s), 7 queries , Gzip On, Redis On.
