查看: 2144|回复: 0
[解决] IDKT加密芯片:防抄板,数据加密,软件授权,生产管控,器件认证,通讯协议保护等。
发表于 2019-12-9 08:54:51 | 显示全部楼层 |阅读模式
General Description
The IDKT is a family of high performance AES256 CODEC with cipher memory device providing 2K Bytes of user memory.
Features
*A illegal Copy Protection IC
*Random Stream Cipher for Interface
*2K Bytes Secure EEPROM
*I2C or 1-Wire Communication Protocol Support 40-bit Unique serial number
*Support MTP/OTP User Area
*Only Increment Counting Function
*for Inkjet Printer and Cartridge
*Input Voltage Range 1.8V ~ 4.5V
*Power On/Off for Low Power Mode
*Available Package SOT23/8SOP/TDFN
Benefits
*Protection illegal reproduction
*Mass production control
*Receiving royalty from SW/HW
Applications
*Authorization using Cipher EEPROM
*Contents Encryption and Decryption
*Network Authorization
*Anti-clone protection
*Secure boot
*Printer cartridge, Water purifier
*All of Electronic Systems Using
   MCU/ CPU / AP
Authentication
产品优势:
1. 双重定制:定制晶圆,定制算法,硬件唯一性2KB EEPROM
2. 国际通用加密算法:AES256随机码流接口。
3. 逻辑电路设计ASIC设计,不能被复制。
4. 销售渠道唯一性:只能通过固定渠道才能拿到货。
5. 产品唯一性:一个型号保证供应给一个客户,防止在市场上流通。
深圳市全球芯科技有限公司(加密芯片/SRAM/pSRAM/图像传感器 13924642346 )
GMT+8, 2025-9-18 16:24 , Processed in 0.012705 second(s), 4 queries , Gzip On, Redis On.
