在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 6577|回复: 17
[统计] ADC最新指标--2018
发表于 2019-1-29 14:39:29 | 显示全部楼层 |阅读模式
Nyquist-Rate ADCs
3.1 A 3.2GS/s 10 ENOB 61mW Ringamp ADC in 16nm with Background
Monitoring of Distortion
3.2 A 7.6mW 1GS/s 60dB SNDR Single-Channel SAR-Assisted Pipelined ADC
with Temperature-Compensated Dynamic Gm-R-Based Amplifier
3.3 A 5GS/s 158.6mW 12b Passive-Sampling 8×-Interleaved Hybrid ADC with
9.4 ENOB and 160.5dB FoMS in 28nm CMOS
3.4 A 0.01mm2 25μW 2MS/s 74dB-SNDR Continuous-Time Pipelined-SAR ADC
with 120fF Input Capacitor
3.5 A 0.6V 13b 20MS/s Two-Step TDC-Assisted SAR ADC with PVT Tracking and
Speed-Enhanced Techniques
3.6 A 6-to-600MS/s Fully Dynamic Ringamp Pipelined ADC with Asynchronous
Event-Driven Clocking in 16nm
3.7 A 10mW 16b 15MS/s Two-Step SAR ADC with 95dB DR Using
Dual-Deadzone Ring-Amplifier
 楼主| 发表于 2019-1-29 14:42:11 | 显示全部楼层
Noise-Shaped & VCO-Based ADCs
20.1 A 5GS/s 7.2 ENOB Time-Interleaved VCO-Based ADC Achieving
30.5fJ/conv-step
20.2 A 40MHz-BW 320MS/s Passive-Noise-Shaping SAR ADC with Passive
Signal-Residue Summation in 14nm FinFET
20.3 A 50MHz-Bandwidth 70.4dB-SNDR Calibration-Free Time-Interleaved
4th-Order Noise-Shaping SAR ADC
20.4 An 8×-OSR 25MHz-BW 79.4dB/74dB DR/SNDR CT ΔΣ Modulator Using 7b
Linearized Segmented DACs with Digital Noise-Coupling-Compensation
20.5 A 76.6dB-SNDR 50MHz-BW 29.2mW Noise-Coupling-Assisted CT Sturdy
MASH ΔΣ Modulator with 1.5b/4b Quantizers in 28nm CMOS
L. Qi1, A. Jain2, D. Jiang1, S-W. Sin1, R. P. Martins1,3, M. Ortmanns2
20.6 An 80MHz-BW 31.9fJ/conv-step Filtering ΔΣ ADC with a Built-In
DAC-Segmentation/ELD-Compensation 6b 960MS/s SAR-Quantizer in
28nm LP for 802.11ax Applications
20.7 A 72.6dB-SNDR 100MHz-BW 16.36mW CTDSM with Preliminary Sampling
and Quantization Scheme in Backend Subranging QTZ
 楼主| 发表于 2019-1-29 14:43:46 | 显示全部楼层
20.1 A 5GS/s 7.2 ENOB Time-Interleaved VCO-Based ADC Achieving 30.5fJ/conv-step
20.2 A 40MHz-BW 320MS/s Passive-Noise-Shaping SAR ADC with Passive Signal-Residue Summation in 14nm FinFET
20.3 A 50MHz-Bandwidth 70.4dB-SNDR Calibration-Free Time-Interleaved 4th-Order Noise-Shaping SAR ADC
20.4 An 8×-OSR 25MHz-BW 79.4dB/74dB DR/SNDR CT ΔΣ Modulator Using 7b Linearized Segmented DACs with Digital Noise-Coupling-Compensation Filter in 7nm FinFET CMOS
20.5 A 76.6dB-SNDR 50MHz-BW 29.2mW Noise-Coupling-Assisted CT Sturdy MASH ΔΣ Modulator with 1.5b/4b Quantizers in 28nm CMOS
20.6 An 80MHz-BW 31.9fJ/conv-step Filtering ΔΣ ADC with a Built-In DAC-Segmentation/ELD-Compensation 6b 960MS/s SAR-Quantizer in 28nm LP for 802.11ax Applications
20.7 A 72.6dB-SNDR 100MHz-BW 16.36mW CTDSM with Preliminary Sampling and Quantization Scheme in Backend Subranging QTZ
发表于 2019-1-29 17:28:42 | 显示全部楼层
发表于 2019-1-29 17:44:37 | 显示全部楼层
回复 1# 雨丝
   能否打个包,我们直接下了
发表于 2019-1-29 19:57:33 | 显示全部楼层
dingiexian
发表于 2019-1-30 09:02:29 | 显示全部楼层
关注,谢谢分享
 楼主| 发表于 2019-1-30 16:36:56 | 显示全部楼层
回复 5# novaming
得下个月才出来吧!
 楼主| 发表于 2019-1-30 16:38:51 | 显示全部楼层
回复 4# novaming
NS SAR这几年真的很热啊!
发表于 2019-1-31 08:25:33 | 显示全部楼层
GMT+8, 2024-5-10 14:53 , Processed in 0.028651 second(s), 6 queries , Gzip On, Redis On.
