Error-[DPI-DIFNF] DPI import function not found
/p/inway/tools/synopsys/vcsmx/N-2017.12/etc/uvm-1.2/base/uvm_resource.svh, 386
The definition of DPI import function/task 'uvm_glob_to_re' does not exist.
Please check the stated DPI import function/task is defined, and its
definition is either passed in a source file at compile-time, or provided in
a shared library specified using the LRM Annex-J options at run-time.
V C S S i m u l a t i o n R e p o r t
Time: 0 ps cpu Time: 0.460 seconds; Data structure size: 0.9Mb
Tue Nov 20 16:23:22 2018
make: *** [run] Error 1
