在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 6104|回复: 5
[求助] cadence仿真时遇到的license问题,各位麻烦帮我看看
发表于 2018-8-18 11:01:31 | 显示全部楼层 |阅读模式
设计好电路图之后点击仿真,出现以下信息,请求各位帮助
Simulating `input.scs' on harroyaan at 10:53:34 AM, Sat Aug 18, 2018 (process id: 58404).
Current working directory: /root/simulation/amplifier/spectre/schematic/netlist
Command line:
    /home/cadence/install/MMSIM151/tools.lnx86/bin/spectre -64  \
        input.scs +escchars +log ../psf/spectre.out +inter=mpsc  \
        +mpssession=spectre6_2076_1 -format psfxl -raw ../psf  \
        +lqtimeout 900 -maxw 5 -maxn 5
spectre pid = 58404
Fatal error found by spectre.
    FATAL: Failed to initialize license API!
lmStatus: ERROR (LMF-01001): License call failed. The license server search path is defined as /home/cadence/install/share/license/license.dat. The FLEXnet error message is as follows,
    FLEXnet ERROR(-1, 212, 2): Cannot find license file.
Run 'lic_error LMF-01001' for more information.
 楼主| 发表于 2018-8-18 14:16:24 | 显示全部楼层
已解决-。-,修改了.bashrc中license的路径
发表于 2018-8-18 20:50:57 | 显示全部楼层
congratulation
 楼主| 发表于 2018-8-29 21:47:21 | 显示全部楼层
回复 3# designstart
   thanks a lot
发表于 2019-3-22 21:07:37 | 显示全部楼层
请问楼主能否讲一下详细步骤,我也遇到这个问题,很头疼。如果方便的话 QQ 825993604
不胜感激
发表于 2022-8-26 10:16:17 | 显示全部楼层
不胜感激
想问下这个问题您解决没,我也遇到了,想请教
GMT+8, 2024-4-27 07:37 , Processed in 0.024549 second(s), 9 queries , Gzip On, Redis On.
