查看: 10120|回复: 5
[求助] WARNING (SPECTRE-16707): Only tran supports psfxl format,
发表于 2018-6-16 21:35:37 | 显示全部楼层 |阅读模式
Simulating `input.scs' on homehost at 8:53:38 PM, Fri Jun 15, 2018 (process id: 5105).
Current working directory: /home/jq/simulation/inv/spectre/schematic/netlist
Command line:
    /opt/eda/mmsim131/tools/spectre/bin/32bit/spectre input.scs  \
        +escchars +log ../psf/spectre.out +inter=mpsc  \
        +mpssession=spectre1_3911_1 -format psfxl -raw ../psf  \
        +lqtimeout 900 -maxw 5 -maxn 5
spectre pid = 5105
Loading /opt/eda/mmsim131/tools.lnx86/cmi/lib/5.0/libinfineon_sh.so ...
Loading /opt/eda/mmsim131/tools.lnx86/cmi/lib/5.0/libphilips_o_sh.so ...
Loading /opt/eda/mmsim131/tools.lnx86/cmi/lib/5.0/libphilips_sh.so ...
Loading /opt/eda/mmsim131/tools.lnx86/cmi/lib/5.0/libsparam_sh.so ...
Loading /opt/eda/mmsim131/tools.lnx86/cmi/lib/5.0/libstmodels_sh.so ...
Reading file:  /home/jq/simulation/inv/spectre/schematic/netlist/input.scs
Reading file:  /opt/eda/mmsim131/tools.lnx86/spectre/etc/configs/spectre.cfg
Reading file:  /home/jq/model/05MIXDTSSA01V12/s05mixdtssa01v12.scs
Reading file:  /home/jq/model/05MIXDTSSA01V12/res_va.va
Reading link:  /opt/eda/mmsim131/tools.lnx86/spectre/etc/ahdl/discipline.h
Reading file:  /opt/eda/mmsim131/tools.lnx86/spectre/etc/ahdl/disciplines.vams
Reading link:  /opt/eda/mmsim131/tools.lnx86/spectre/etc/ahdl/constants.h
Reading file:  /opt/eda/mmsim131/tools.lnx86/spectre/etc/ahdl/constants.vams
Entering remote command mode using MPSC service (spectre, ipi, v0.0, spectre1_3911_1, ).
Warning from spectre.
    WARNING (SPECTRE-16707): Only tran supports psfxl format, result of other analyses will be in psfbin format.
ic616和mmsim13、mmsim10多会有上述Warning,ic5141和mmsim10正常,不知道是不是要加什么参数。
路过的那位知道哪里有问题,请赐教
 楼主| 发表于 2018-6-19 11:53:52 | 显示全部楼层
这个警告并没有影响仿真波形图正常输出,不知哪里能设置统一输出仿真格式
发表于 2019-7-24 10:11:42 来自手机 | 显示全部楼层
在ADE中output-save all-output format中选择
发表于 2019-7-24 10:11:58 来自手机 | 显示全部楼层
发表于 2020-2-19 17:35:31 | 显示全部楼层
可是在save all里面压根没有output format这个选项呀?我的是MMSIM121版本
回复 支持 0 反对 1
发表于 2021-3-6 15:17:03 | 显示全部楼层
管用
GMT+8, 2025-12-29 03:45 , Processed in 0.016083 second(s), 4 queries , Gzip On, Redis On.
