在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 1848|回复: 0
[求助] RF AMP 入门 设计,求帮助。
发表于 2018-3-21 22:40:37 | 显示全部楼层 |阅读模式
Most amplifiers need some sort of bias up sequence. Suppose you have a 2W RF power amplifier that runs at ~25% efficiency. The power amplifier operates at a drain voltage of 6 V, a drain current of 1.3 A and a gate bias somewhere between -2 V and -1 V. The amplifier requires a bias up sequence as follows:
1) With the drain voltage Vg turned off, the bias voltage must be set to -2V
2) The drain voltage is then turned on to +6V
3) The gate voltage is increased until the amplifier draws 1.3 A.
The bias up sequence can be done with an integrated bias controller such as the HMC980. However, at 6V and 1.3 A, > 1 Watt is dissipated as wasted heat in this bias controller (hint: why?). Because power is a major constraint on a satellite, design a circuit to provide this bias functionality while dissipating half the power as the HMC980.
刚入门,rf , 求帮助。
GMT+8, 2025-7-13 00:27 , Processed in 0.013289 second(s), 9 queries , Gzip On, MemCached On.
