查看: 3359|回复: 1
[讨论] CCS6编译不过
发表于 2017-11-1 13:41:06 | 显示全部楼层 |阅读模式
悬赏10资产未解决
代码错误行:
switch(((CMD_UNION)(v->pSor[*v->pThread])).bit_inst.Cmd)其中CMD_UNION定义为:
typedef union {
   UINT16  all;
   struct CMDSTRUCT bit_inst;
}CMD_UNION;
v定义为:
typedef struct {  INT16 *pSor;
              UINT16* pThread;
} PPPARAM;
error:#120 cast to type "CMD_UNION" is not allowed        ProgParam.c
用F28M35的M3核编译是可以编译过的,用F28377D的CUP1核就编译不过,为什么呢?
 楼主| 发表于 2017-11-2 13:52:01 | 显示全部楼层
修改为switch(((CMD_UNION)((UINT16)v->pSor[*v->pThread])).bit_inst.Cmd)
GMT+8, 2025-10-27 06:00 , Processed in 0.571225 second(s), 5 queries , Gzip On, Redis On.
