在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 1723|回复: 2
[求助] How to find the library features
发表于 2017-7-3 05:08:45 | 显示全部楼层 |阅读模式
I am running synthesis in DC with loaded a few library DB's:
Loading db file '/home/dubeeloo/proj/DFTcompiler/DFTorTiming/sc_max.db'
Loading db file '/home/dubeeloo/proj/DFTcompiler/DFTorTiming/io_max.db'
Loading db file '/home/dubeeloo/proj/DFTcompiler/DFTorTiming/rams_max.db'
Loading db file '/home/dubeeloo/proj/DFTcompiler/DFTorTiming/special.db'
But my setting wire_load_model:
set_wire_load_model –name LARGE
and
setting operating conditions:
set_operating_conditions WORST
all turn out to be errors, :
The library in db format is not readable, does DC have a command that could give me
library information, like wire load models I could use, what operation conditions I could use
Please help
发表于 2017-7-3 10:37:55 | 显示全部楼层
report_lib
 楼主| 发表于 2017-7-4 02:01:18 | 显示全部楼层
回复 2# swary
   thank you for the reply
GMT+8, 2024-5-10 20:49 , Processed in 0.017174 second(s), 6 queries , Gzip On, Redis On.
