Loading Lef file designKit/cic_tsmc18/aprSoCE/lef/tsmc18_6lm.lef...
Set DBUPerIGU to M2 pitch 1320.
Initializing default via types and wire widths ...
Loading Lef file designKit/cic_tsmc18/aprSoCE/lef/tpz973g_5lm.lef...
Loading Lef file designKit/cic_tsmc18/aprSoCE/lef/tsmc18_6lm_antenna.lef...
**WARN: (SOCLF-58): Cell 'FILL8' has been found in the database. The cell
has already been defined in another LEF file, or earlier in this
LEF file. All data except the antenna data will be ignored. If
the data in both cell definitions is needed, manually merge the
data into one definition.
**WARN: (SOCLF-58): Cell 'FILL64' has been found in the database. The cell
**WARN: (SOCLF-58): Cell 'FILL4' has been found in the database. The cell
**WARN: (SOCLF-58): Cell 'FILL32' has been found in the database. The cell
**WARN: (SOCLF-58): Cell 'FILL2' has been found in the database. The cell
**WARN: (SOCLF-58): Cell 'FILL16' has been found in the database. The cell
**WARN: (SOCLF-58): Cell 'FILL1' has been found in the database. The cell
data into one definition. |
