大家好,magic-semi是中文名字是上海实真微电子有限公司,之前发的帖子楼可能歪了,给一些人造成误解。
现郑重声明: magic-semi不是一个收费培训公司,招聘的是正式员工和实习生。 欢迎您的加入
1. 实习生职位
Magic-semi JD forIntern Magic-semi is a new startup design servicecompany specialized in backend training, consulting and design service. In magic-semi, design experters with rich experience in advancetechnology nodes from 40nm to 14nm and can deliver complete solutionfrom netlist to GDSII. Magic-semi has good relationship with IC leadingcompany and enables our customer to achieve success in a more efficient,reliable and cost-effective way.
RESPONSIBILITES: 1. Responsible for developing digital designswith emphasis on backend, including Floor-plan,powerplanning, Place, CTS andRoute. 2. Work with Front-end designers to optimizetiming/area/power of the design implementation and perform static timinganalysis. 3. Optimization and Verification of layoutfor tape-out (including RC extraction, ECO, DRC, LVS). 4. Static Timing analysis (Prime Time or ETS)and setup/hold fix. Requirements: 1.
CS/EE or background in areas related todigital or Analog chip design 2.
Known of IC backend flow. 3.
Known of timing concept. 4.
Have reading and writing skills forenglish 5.
Experience in floorplan, place, cts,route, timing ,pv and power analysis and so on. 6.
Experienced in Synopsys/Cadenceautomatically physical implementation tools and flows (IC-Compiler/ Astro /SOC-Encounter/ Milky-way/ Star-RCX) is a plus. 7.
Experience with one or more scriptinglanguages (Perl, TCL, or Shell) to make reusable automatically flow is a plus. 8.
Experience and knowledge about FE design(RTL code, flow) and verification is a plus. 9.
Good analytical and debugging skills.
Send your CV to hr@magic-semi.com if you are interested.
2.应届生
Magic-semi JD for NCG Magic-semi is a new startup design servicecompany specialized in backend training, consulting and design service. In magic-semi, design experters with rich experience in advancetechnology nodes from 40nm to 14nm and can deliver complete solutionfrom netlist to GDSII. Magic-semi has good relationship with IC leadingcompany and enables our customer to achieve success in a more efficient,reliable and cost-effective way.
Job Title: Intern/NCG
RESPONSIBILITES: 1. Responsible for developing digital designswith emphasis on backend, including Floor-plan, power planning, Place, CTS andRoute. 2. Work with Front-end designers to optimize timing/area/powerof the design implementation and perform static timing analysis. 3. Optimization and Verification of layoutfor tape-out (including RC extraction, ECO, DRC, LVS). 4. Static Timing analysis (Prime Time or ETS)and setup/hold fix. Requirements: 1.
CS/EE or background in areas related todigital or analog chip design 2.
Be familiar with IC backend flow. 3.
Experienced in Synopsys/Cadenceautomatically physical implementation tools and flows (IC-Compiler/ Astro /SOC-Encounter/ Milky-way/ Star-RCX) is a plus. 4.
Experience with one or more scriptinglanguages (Perl, TCL, or Shell) to make reusable automatically flow is a plus. 5.
Experience and knowledge about FE design(RTL code, flow) and verification is a plus. 6.
3. 高级工程师
Magic-semi JD forSenior Engineer Magic-semi is a new startup design servicecompany specialized in backend training, consulting and design service. In magic-semi, design experters with rich experience in advancetechnology nodes from 40nm to 14nm and can deliver complete solutionfrom netlist to GDSII. Magic-semi has good relationship with IC leadingcompany and enables our customer to achieve success in a more efficient,reliable and cost-effective way.
Job Title: Senior Engineer
3 year+ work experience. 3.
experience in floorplan, place, cts,route, timing ,pv and power analysis and so on. 4.
Experienced in Synopsys/Cadenceautomatically physical implementation tools and flows (IC-Compiler/ Astro /SOC-Encounter/ Milky-way/ Star-RCX) is a plus. 5.
Experience with one or more scriptinglanguages (Perl, TCL, or Shell) to make reusable automatically flow is a plus. 6.
Experience and knowledge about FE design(RTL code, flow) and verification is a plus. 7.
4. leader
Magic-semi JD forLeader Engineer Magic-semi is a new startup design servicecompany specialized in backend training, consulting and design service. In magic-semi, design experters with rich experience in advancetechnology nodes from 40nm to 14nm and can deliver complete solutionfrom netlist to GDSII. Magic-semi has good relationship with IC leadingcompany and enables our customer to achieve success in a more efficient,reliable and cost-effective way.
Job Title: Leader Engineer
7 year+ work experience for IC backend. 3.
Experience in floorplan, place, cts,route, timing ,pv and power analysis and so on. 4.
Have experience for project management. 5.
Experienced in Synopsys/Cadenceautomatically physical implementation tools and flows (IC-Compiler/ Astro /SOC-Encounter/ Milky-way/ Star-RCX) is a plus. 6.
Experience with one or more scriptinglanguages (Perl, TCL, or Shell) to make reusable automatically flow is a plus. 7.
Experience and knowledge about FE design(RTL code, flow) and verification is a plus. 8.
Good analytical and debugging skills. 9.
Self-motivated and good team player.
Send your CV to hr@magic-semi.com if you are interested. |
