查看: 114408|回复: 405
[资料] Cadence SpectreRF workshop全套资料
发表于 2015-6-22 21:39:30 | 显示全部楼层 |阅读模式
之前有人发过http://bbs.eetop.cn/thread-229541-1-1.html但是没有找到下载的地方,所以我再发一次
全套资料包括:LNA、Mixer、VCO、PA、PLL
(1)LNA
Lower Noise Amplifier Design Measurements .................................................................. 3
Purpose........................................................................................................................... 3
Audience ......................................................................................................................... 3
Overview........................................................................................................................ 3
Introduction to LNAs.......................................................................................................... 3
The Design Example: A Differential LNA......................................................................... 4
Testbench ........................................................................................................................ 5
Example Measurements Using SpectreRF.......................................................................... 5
Lab1: Small Signal Gain (SP)......................................................................................... 6
Lab2: Large Signal Noise Simulation (PSS and Pnoise) .............................................. 17
Lab3: Gain Compression and Total harmonic Distortion (Swept PSS) ....................... 24
Lab4: IP3 Measurement---PSS Plus PAC analysis....................................................... 34
Lab5: IP3 Measurement---QPSS Analysis with Shooting or Flexible Balance Engine40
Lab6: IP3 Measurement---Rapid IP3 using AC analysis.............................................. 49
Lab7: IP3 Measurement ---Rapid IP3 using PSS Plus PAC Analysis.......................... 53
Conclusion ........................................................................................................................ 58
Reference .......................................................................................................................... 58
(2)Mixer
Mixer Design Measurements .......................................................................... 3
Introduction to Mixers..................................................................................... 3
The Design Example: A Differential Input Mixer.......................................... 4
Example Measurements Using SpectreRF...................................................... 6
Lab1: Voltage Conversion Gain Versus LO Signal Power (Swept PSS with PAC) ...... 6
Lab2: Voltage Conversion Gain Versus RF Frequency (PSS and Swept PAC)........... 16
Lab3: Voltage Conversion Gain Versus RF Frequency (PSS and Swept PXF) ........... 21
Lab4: Power Conversion Gain Versus RF Frequency (QPSS)..................................... 26
Lab5: Periodic S-Parameters (PSS and PSP)................................................................ 31
Lab6: Noise, Noise Figures and Noise Summary (PSS and Pnoise) ........................... 38
Lab7: Port-to-Port Isolation Among RF, IF and LO Ports (PSS and Swept PAC) ..... 44
Lab8: Mixer Performance with a Blocking Signal (QPSS, QPAC, and QPNoise) ..... 55
Lab9: IP3 Calculation (Swept QPSS and QPAC)........................................................ 66
Lab10: IP3 Calculation (QPSS with Shooting Engine or Flexible Balance Engine) ... 74
Lab11: Rapid IP3 (PAC)............................................................................................... 84
Lab12: Compression Distortion Summary (PAC)....................................................... 88
Lab13: Rapid IP2 (PAC)............................................................................................... 92
Lab14: IM2 Distortion Summary (PAC) ...................................................................... 97
Conclusion...................................................................................................100
Reference.....................................................................................................101
(3)VCO
Voltage Controlled Oscillator Design Measurements ........................................................ 3
Introduction to VCOs.......................................................................................................... 3
The Design Example: oscHartley ....................................................................................... 4
Lab1: Output Frequency, Output Power, Phase Noise and Jitter ................................... 6
Measurement (Pnoise with shooting or Flexible Balance engine)........................ 6
Lab2: Frequency Pushing (Swept PSS) ........................................................................ 29
Lab3: Tuning Sensitivity and Linearity (Swept PSS)................................................... 34
Lab4: Power Dissipation (PSS) ................................................................................... 40
Lab5: Frequency Pulling (Swept PSS) ........................................................................ 45
Conclusion ........................................................................................................................ 50
Reference .......................................................................................................................... 51
(4)PA
Power Amplifier Design Using SpectreRF......................................................................... 3
Introduction to Power Amplifiers ....................................................................................... 3
The Design Example........................................................................................................... 3
Three Testbenches for PA Measurements ...................................................................... 4
Lab 1: Power Related Measurement (Swept PSS).......................................................... 6
Lab 2: Linearity Measurement (Swept PSS with PAC)................................................ 19
Lab 3: Stability and S-Parameter Measurements (PSS and PSP) ................................. 29
Lab 4: Large Signal S-Parameter Measurement (LSSP Wizard).................................. 42
Lab 5: Load-Pull Measurements (Swept PSS).............................................................. 50
Lab 6: Envelope Following Analysis (ENVLP and ACPR Wizard) ............................ 63
Using the ACPR Wizard........................................................................................... 78
Conclusion ........................................................................................................................ 83
Reference .......................................................................................................................... 83
(5)PLL
Introduction to Noise-Aware PLL Design Flow...........................................................................3
Downloading GPDK180 .............................................................................................................6
Integer-N PLL design flow........................................................................................................10
Creating a CMI Model for the VCO/Divider..............................................................................10
Creating a Model for the PFD/CP..............................................................................................20
(optional) Creating a Model for the Divider ...............................................................................28
Fractional-N PLL Design Flow .................................................................................................51
Creating a CMI Model for the VCO/Divider..............................................................................51
Creating a Model for the PFD/CP..............................................................................................57
Simulating a Fractional-N PLL..................................................................................................57
Noise Aware PLL flow FAQs ...................................................................................................66
LNA_workshop_instruction.pdf (2.24 MB , 下载次数: 3038 )
Mixer_workshop_instruction.pdf (3.91 MB , 下载次数: 2793 )
VCO_workshop_instruction.pdf (1.86 MB , 下载次数: 2830 )
PA_workshop_instruction.pdf (3.09 MB , 下载次数: 2994 )
PLL_workshop_instruction.pdf (3.72 MB , 下载次数: 3695 )
发表于 2015-6-23 02:56:51 | 显示全部楼层
IF you can also upload the lab and labguide, that's great
 楼主| 发表于 2015-6-23 08:26:36 | 显示全部楼层
回复 2# peepeekid
oh,sorry,that is so difficult and I can't finish it .I think the official document is the most authoritative and credible.
发表于 2015-6-23 09:33:09 | 显示全部楼层
感謝你的分享!!!!
发表于 2015-7-24 19:16:38 | 显示全部楼层
谢谢分享
发表于 2015-7-31 04:14:47 | 显示全部楼层
谢谢分享
发表于 2015-8-10 14:52:24 | 显示全部楼层
thx  for sharing~
发表于 2015-8-14 10:22:44 | 显示全部楼层
too old~~
发表于 2015-8-24 15:12:02 | 显示全部楼层
thx..share
发表于 2015-8-24 15:44:04 | 显示全部楼层
good to read them
GMT+8, 2025-12-4 01:58 , Processed in 0.025374 second(s), 7 queries , Gzip On, Redis On.
