在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 3097|回复: 4
pnoise分析无法画出相位噪声图 || Can't plot phase noise
发表于 2015-6-22 11:43:17 | 显示全部楼层 |阅读模式
最近遇到了这个问题,感觉甚是奇怪,以前明明没有这个问题。CIW里大概会提示cannot handle nil , cannot evaluate pnoise之类的问题。
好在通过谷歌搜索找到了答案,原来2006年就有国人问过这个问题了,当时问这个问题的人是CAO Zhiheng。
原帖来自:http://www.44342.com/cad-f228-t47-p1.htm
翻译成中文,简要的来说,就是不要用+、-这样的特殊字符,如果你的net都是英文字母,就不会出现这个诡异的问题。
Can't plot phase noise from pnoise result window in SpectreRF
Postby Zhiheng Cao » Thu, 16 Mar 2006 08:31:43 GMT
Dear Cadence,
I followed the instruction manual to simulate phase noise
of a LC oscillator, I run the pss analysis and pnoise analysis.
Then, when I try to plot results of pnoise, I can plot
"Output Noise", however, when I chose "Phase Noise" it
says
"Output nodes of pnoise analysis not saved for pss analysis.
As a result, the above selected function cannot be executed."
I have restarted Cadence, redrew the schematic, set
Output->Save All... and checked "all" everywhere, but I still
cannot plot phase noise. What is my problem?
Best Regards,
Zhiheng
Re: Can't plot phase noise from pnoise result window in SpectreRF
Postby Andrew Beckett » Wed, 22 Mar 2006 00:52:47 GMT
What version are you using (what does Help->About... in the CIW say)? I recall
this being a bug at some point in the past, which has been fixed.
I vaguely recall it being an issue if your output nodes contained odd
characters (such as "+" and "-"). If you stuck to alphabetic characters,
all was OK...
Andrew.
发表于 2015-6-23 12:51:09 | 显示全部楼层
其实icfb里大部分的程序都是用skill脚本实现,而这些脚本或者以明文方式存在,或者以密文存在,如果能找到功能实现的脚本,那么大部分问题就迎刃而解
发表于 2016-3-17 19:41:27 | 显示全部楼层
don;t know this issue !
发表于 2016-8-16 17:33:40 | 显示全部楼层
learning !!!
发表于 2016-8-16 18:03:26 | 显示全部楼层
非常感谢,
GMT+8, 2024-4-26 18:49 , Processed in 0.024733 second(s), 8 queries , Gzip On, Redis On.
