在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
楼主: eemms20
[资料] The UVM Primer - Ray Salemi
发表于 2015-6-15 21:55:01 | 显示全部楼层
谢谢分享
发表于 2015-6-17 16:28:21 | 显示全部楼层
发表于 2015-6-26 12:49:36 | 显示全部楼层
内容谢谢,找了好久的资料
发表于 2015-6-26 12:54:20 | 显示全部楼层
The UVM Primer uses simple, runnable code examples, accessible analogies, and an easy-to-read style to introduce you to the foundation of the Universal Verification Methodology. You will learn the basics of object-oriented programming with SystemVerilog and build upon that foundation to learn how to design testbenches using the UVM. Use the UVM Primer to brush up on your UVM knowledge before a job interview to be able to confidently answer questions such as "What is a uvm_agent?" , "How do you use uvm_sequences?", and "When do you use the UVM's factory." The UVM Primer's downloadable code examples give you hands-on experience with real UVM code. Ray Salemi uses online videos (on uvmprimer.com) to walk through the code from each chapter and build your confidence. Read The UVM Primer today and start down the path to the UVM.
发表于 2015-6-30 22:34:05 | 显示全部楼层
very good, thanks
发表于 2015-7-2 11:22:24 | 显示全部楼层
What is the basic requirements for the UVM?
Is that required the fundemantals of systemverilog?
发表于 2015-7-2 13:08:10 | 显示全部楼层
回复 1# eemms20
正需要,多谢!
发表于 2015-7-2 16:49:58 | 显示全部楼层
找了好久,感谢
发表于 2015-7-2 20:43:20 | 显示全部楼层
好东西,感谢分享
发表于 2015-7-2 22:02:18 | 显示全部楼层
thanks for sharing.
GMT+8, 2024-4-27 09:05 , Processed in 0.037806 second(s), 5 queries , Gzip On, Redis On.
