在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 27511|回复: 21
[资料] 分享English for Research Usage, Style, and Grammar
发表于 2014-10-29 14:21:20 | 显示全部楼层 |阅读模式
图书作者:Adrian Wallwork 图书标题:English for Research Usage, Style, and Grammar出版社:springer出版日期:2013Who is this book for?       This book is aimed at anyone who writes research papers, whose first language is not English, and who needs guidance regarding the grammar,usage, and style of academic English. It should also be useful for those who edit or proofread research papers.It is suitable for those whose level of English is mid intermediate or higher.
How is the book organized?       The book is organized into 28 chapters on various aspects of English usage. This means that in the same chapter you will fi nd all issues related to, for example, the use of tenses. However, some grammatical items are separated for convenience. For example, you will fi nd the use of adverbs in three different sections: Chapter 13 deals with how adverbs are used as link words, Chapter 14 with typical differences between the various adverbs of time and place, and Chapter 17 with where adverbs are located within a phrase.        In each subsection, you will fi rst fi nd numbered guidelines. When there are four or more rules, the last few rules are generally the least important.       In the table below the guidelines, there are examples of sentences that implement (or fail to implement) the rules.       Good and bad examples are contained in the columns of the table entitled ‘Yes’ and ‘No’, respectively. The ‘No’ examples indicate typical mistakes taken from drafts of real papers. Most of the ‘Yes’ examples have been adapted from sentences written by native English speakers.       Sometimes in alternative to ‘Yes’ and ‘No’, one column is devoted to how one word or tense is used, and the other to how a related word or tense is used.       There is an index at the end of the book to help you fi nd the particular grammar or style issue that you wish to review.
 楼主| 发表于 2014-10-29 14:29:19 | 显示全部楼层
附件来了 English_for_Research_Usage,_Style,_and_Grammar.pdf (1.62 MB, 下载次数: 131 )
发表于 2015-2-2 10:21:37 | 显示全部楼层
下载下来看看和中学时学的英语结构有什么区别,以便在后续工作中,避免犯一些不该犯的错误!谢谢楼主!
发表于 2015-2-3 02:27:53 | 显示全部楼层
正在写论文 应该会有用
发表于 2015-5-18 22:26:04 | 显示全部楼层
English_for_Research_Usage,_Style,_and_Grammar.pdf (1.62 MB)
发表于 2015-11-21 00:19:23 | 显示全部楼层
回复 2# lyneesky
Thanks!
发表于 2015-11-29 15:53:26 | 显示全部楼层
下来看看,谢谢。
发表于 2016-1-28 00:35:56 | 显示全部楼层
Thanks for sharing
发表于 2016-4-5 11:35:40 | 显示全部楼层
thanks for sharing
发表于 2016-4-13 22:37:48 | 显示全部楼层
感謝分享
GMT+8, 2024-4-27 05:43 , Processed in 0.028820 second(s), 7 queries , Gzip On, Redis On.
