在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 6609|回复: 24
[资料] 拉扎维最牛著作_A 10-Bit 500-MSs 55-mW CMOS ADC
发表于 2014-3-23 11:30:14 | 显示全部楼层 |阅读模式
拉扎维最牛著作_A 10-Bit 500-MSs 55-mW CMOS ADC.pdf (1.26 MB, 下载次数: 356 )
 楼主| 发表于 2014-3-23 14:02:32 | 显示全部楼层
好定西~~挺一个
发表于 2014-3-23 18:11:53 | 显示全部楼层
谢谢分享
Ashutosh Verma, Member, IEEE, and Behzad Razavi, Fellow, IEEE
Abstract—A pipelined ADC incorporates a digital foreground
calibration technique that corrects errors due to capacitor mismatch, gain error, and op amp nonlinearity. Employing a highspeed, low-power op amp topology and an accurate on-chip resistor ladder and designed in 90-nm CMOS technology, the ADC
achieves a DNL of 0.4 LSB and an INL of 1 LSB. The prototype digitizes a 233-MHz input with 53-dB SNDR while consuming 55 mW
from a 1.2-V supply.
发表于 2014-3-23 18:12:27 | 显示全部楼层
谢谢分享
发表于 2014-3-24 01:33:12 | 显示全部楼层
学术paper, 工业界应用有很明显的缺陷
 楼主| 发表于 2014-3-24 09:38:30 | 显示全部楼层
回复 5# hezudao
缺陷在哪?大神,不妨指导一下!
发表于 2014-3-24 13:23:05 | 显示全部楼层
非常感谢提供!
发表于 2014-3-25 09:42:19 | 显示全部楼层
工业界比这牛多了! 特别是面积方面。
贴个工业界IP的指标吧!
 40nm SMIC Low Leakage (LL)
 No Analog Options
 1.1V Core & 2.5V I/O Supplies
 12-bit ADC
 Sampling Rate up to 250MS/s
 High-Speed SAR-based Architecture
 Differential Input Signal Range: 1.0Vppdiff
 Outstanding Dynamic Performance
o 76dB SFDR at fin=10MHz
o -75dB THD at fin=10MHz
o 63.5dB SNR at fin=10MHz
o 63.1dB SNDR at fin=10MHz
o 10.2-bit ENOB at fin=10MHz
 Stand-by and Power Down Modes
 Ultra Low Power Dissipation: Only 6mW
 Ultra Compact Die Area: Only 0.09mm2
 楼主| 发表于 2014-3-26 14:45:01 | 显示全部楼层
顶起来~~~
发表于 2014-6-27 19:50:43 | 显示全部楼层
good papers !
GMT+8, 2024-4-27 13:02 , Processed in 0.029769 second(s), 7 queries , Gzip On, Redis On.
