楼主 |
发表于 2013-10-9 23:00:08
显示全部楼层
回复 12# wafer_2013
Oops... Actually your Ubuntu version is a little bit outdated for me, adding on you didn't specify your problem quite clearly, I have no idea about how to solve your problem, sorry for that.
Also, from my point of view, the problem you mentioned has not so much connection with the issue of whether you need to patch for 64 bit version or not. But after installation, it's necessary to patch your mmsim before instant use. As for the choice of 32 or 64-bit patch depends on your system.
The last but not least thing is, it's quite weird that you cannot find a log file. Please check the path again, if you can't get access to the log, you will not know what's the matter with your IC software.
Good luck, pal! |
