在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 11409|回复: 10
Sentaurus运行及License的问题
发表于 2013-6-11 16:58:45 | 显示全部楼层 |阅读模式
我运行lmgrd的时候,显示
“license manager: can't initialize: No SERVER lines in license file.
License path:  /usr/Agilent/agilent.lic:
FLEXnet Licensing error:-13,66
我输入GENESISe的时候,显示“command not found”
请问是什么问题?谢谢!
注:由于我安装的linux系统是学校的服务器上的,我没有改写rc.local的权限。这步骤我没有做。
我的synopsis.dat文件内容如下:jupiter是服务器的名字
SERVER jupiter 001ec9b60e0f 27000
DAEMON snpslmd /home/yinny11/Sentaurus/Install/scl/linux/bin/snpslmd.exe
FEATURE SSS snpslmd 1.0 31-dec-2020 uncounted CEA2EA8BDE6DC12E3AB0 \
VENDOR_STRING="69656 d1d88 34cc3 3f943 c7eb9 df1ac c59a4 23589 \
aa9a3 196" HOSTID=001ec9b60e0f ISSUER="Team ZWT 2006" \
NOTICE="Licensed to mammoth//ZWT 2006 [PLEASE DO NOT DELETE THIS \
SSS KEY]" SN=RK:1978-0:001224:0 START=1-jan-2006
PACKAGE EFA_Synopsys_1 snpslmd 2019.12 60A0B09179801CF480B8 COMPONENTS="AdvanceCalibration_all \
sde_all sdevice-3d_all sdevice-densitygrad_all sdevice-ferro_all sdevice-floatinggate_all \
sdevice-gateleakage_all sdevice-hetero_all sdevice-hydro_all sdevice-kpgain_all \
sdevice-laser_all sdevice-led_all sdevice-mixedmode_all sdevice-montecarlo_all \
sdevice-noise_all sdevice-optic_all sdevice-parallel4_all sdevice-parallel_all \
sdevice-pmi_all sdevice-radiation_all sdevice-reliability_all sdevice-schroedinger_all \
sdevice-sige_all sdevice-thermo_all sdevice-traps_all sdevice-vectoroptic_all sdevice_all \
sdevicemonosemicond_all sprocess-an-imp3d_all sprocess-parallel4_all sprocess-parallel_all \
sprocess2d_all sprocess2dmc_all sprocess3d_all sprocess3dmc_all sprocess_all sprocessmc_all \
sup2lig_all swb-advanced_all swb_all Sxtract_all Tdx_all Tecplot_all TecplotSmall_all \
Ted_all TedSmall_all alien2lig_all amat-calib_all Devise_all Devise-3D_all \
Dfisetools-Topo_all GENESISe_all Noffset-2D_all OptimISE-DOE_all OptimISE-Iterative_all \
OptimISE-RSMOpt_all OptimISE-Statistical_all prmspx_visual_all sde3d_all sdevcie-laser_all \
sparallel_all spcmcalib_all spcmstd_all sprocesskmc_all sprocessmpp_all sptopography2d_all \
vsea-calib_all" ck=173
PACKAGE EFA_Synopsys_2 snpslmd 2019.12 10D0A0215EA04DCA2D65 COMPONENTS="AdvanceCalibration_all \
AdvancedCalibration_all AN-Impl3D_all Dessis-3D_all Dessis-BONSIM_all Dessis-DensityGrad_all \
Dessis-Ferro_all Dessis-FloatingGate_all Dessis-GateLeakage_all Dessis-Hetero_all \
Dessis-Hydro_all Dessis-kpGain_all Dessis-kpGain_all Dessis-Laser_all Dessis-LED_all \
Dessis-MixedMode_all Dessis-Mono-Semicond_all Dessis-MonteCarlo_all Dessis-Noise_all \
Dessis-Optic_all Dessis-Parallel4_all Dessis-Parallel_all Dessis-PMI_all \
Dessis-Radiation_all Dessis-Reliability_all Dessis-Schroedinger_all Dessis-SiGe_all \
Dessis-Thermo_all Dessis-Traps_all Dessis-VectorOptic_all Dessis_all Dfisetools_all \
Dios-3D_all Dios-MC_all Dios-PDEF_all Dios-SDO_all Dios_all DiosSmall_all Dip_all \
Emlab-Dessis_all Emlab-Farfield_all Emlab-Nonuniform-2D_all Emlab-Nonuniform-3D_all \
Emlab-Static_all Emlab-Thermal_all Emlab-Uniform-2D_all Emlab-Uniform-3D_all Emlab_all \
emw-farfield_all emw-nonuniform-2d_all emw-nonuniform-3d_all emw-sdevice_all emw-static_all \
emw-thermal_all emw-uniform-2d_all emw-uniform-3d_all emw_all Floops-1D-MC_all Floops-1D_all \
Floops-2D-MC_all Floops-2D_all Floops-3D-MC_all Floops-3D_all Floops-Parallel4_all \
Floops-Parallel_all Inspect_all Interfise_all ISExtract_all Ligament_all LigamentFE_all \
Mesh1D_all Mesh2D_all Mesh3D_all Noffset-3D_all ParDiSo_all Prolyt_all" ck=226
FEATURE EFA_Synopsys_1 snpslmd 2019.12 31-dec-2019 9999 9ED2DA9B1C2C6B5ED248 \
VENDOR_STRING=^1Platform:ALL+S SUPERSEDE ISSUER=SYNOPSYS ISSUED=11-jul-2001 ck=116 \
START=11-jul-2001
FEATURE EFA_Synopsys_2 snpslmd 2019.12 31-dec-2019 9999 2E824A9B57FD1BC6304B \
VENDOR_STRING=^1Platform:ALL+S SUPERSEDE ISSUER=SYNOPSYS ISSUED=11-jul-2001 ck=21 \
START=11-jul-2001
发表于 2013-6-11 21:17:01 | 显示全部楼层
问题应该是没有在.bash_profile文件加入export PATH=.......
 楼主| 发表于 2013-6-12 15:46:19 | 显示全部楼层
回复 2# lzsz
    我有写的。sen路径/bin和scl路径/bin,都有的。
 楼主| 发表于 2013-6-12 17:01:12 | 显示全部楼层
问题补充:
终端上完整的提升是
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com".
发表于 2013-6-12 19:32:47 | 显示全部楼层
回复 4# Lanton
license path指向的文件好像不是synopsys.dat
发表于 2013-6-14 03:26:42 | 显示全部楼层
 楼主| 发表于 2013-6-14 10:31:23 | 显示全部楼层
回复 6# zjwumei
   谢谢~
发表于 2015-9-12 12:49:57 | 显示全部楼层
路过!
发表于 2017-3-20 15:33:39 | 显示全部楼层
回复 2# lzsz
大神请问一下我装2013时现在一直报hostid不匹配的问题,具体是我输ifconfig 地址显示为em1 em2 em3 等等,无eth0, 破解的时候看到教程里面都是eth0,生成dat文件时直接用的em1,我的redhat 版本是Scientific linux release 6.6(Carbon),求大神指明方向,到底那里有问题呀,十分感谢了。
发表于 2019-4-6 11:29:35 | 显示全部楼层
GMT+8, 2025-5-14 01:24 , Processed in 0.031207 second(s), 10 queries , Gzip On, MemCached On.
