查看: 49176|回复: 43
ic616安装之后启动时出现问题
发表于 2013-6-7 00:44:06 | 显示全部楼层 |阅读模式
我在Ubuntu 12.04 64位上安装ic616    但启动时出现以下问题
WARNING: HOST <hushuai-Aspire-4745G> DOES NOT APPEAR TO BE A CADENCE SUPPORTED LINUX CONFIGURATION.
         For More Info,  Please Run '<cdsroot>/tools.lnx86/bin/checkSysConf' <productId>.
virtuoso:   ERROR: The OA2.2 library directory (/home/hushuai/cadence/installs/IC616/oa_v22.43.018/lib/linux_rhel40_gcc44x_32/opt) does not seem to exist.
virtuoso:    INFO: You have OA_UNSUPPORTED_PLAT set to "linux_rhel40_gcc44x" in your environment:
virtuoso:          check that the value provided correspond to a valid OA platform.
virtuoso:          If this value is correct, check your OA installation.
virtuoso:    INFO: Note that OpenAccess (OA) requires running the Configure phase.
virtuoso:          See the "OpenAccess Installation and Configuration Guide" before
virtuoso:          you complete the configuration step. This manual is included with
virtuoso:          the Cadence product documentation.
小弟刚接触这些东西,还请各位帮忙
发表于 2013-6-7 03:26:19 | 显示全部楼层
please install centos or redhat
why have you installed ubuntu for cadence?
redhat, centos and suse enterprise compatible with cadence and synopsys
 楼主| 发表于 2013-6-7 10:11:27 | 显示全部楼层
回复 2# mabas.masood
    当时感觉都可以装,所以就。。。
发表于 2013-7-10 11:30:44 | 显示全部楼层
You might try SUSE Linux Enterprise Server, it is also a supported platform.
发表于 2013-8-20 03:24:11 | 显示全部楼层
坛子里有解答,只要在.BASHRC里加一句 SUPPORTED PLATFORM ... 就可以了。
我还没有遇到因为LINUX版本不能装的。
发表于 2013-11-9 15:07:15 | 显示全部楼层
回复 5# YULONGUTK
    你好,我也遇到了这个问题,请问具体的怎么设置,我在论坛里便没找到,,谢谢哈
发表于 2013-11-27 10:47:21 | 显示全部楼层
请问楼主,我用的就是坛子里的IC616.s005base版本的,但是用iscape4.20安装不了,不知道楼主是如何安装的?请赐教哈,非常感谢!!
发表于 2014-2-19 16:47:37 | 显示全部楼层
我也遇到了这个问题,请问解决了吗
发表于 2014-3-3 17:13:08 | 显示全部楼层
比较奇怪,同样的系统,以前没问题,现在居然也报这个问题了
发表于 2014-4-21 11:04:49 | 显示全部楼层
我遇到如下的问题,不知道是不是系统的问题-- oracle linux:
virtuoso:   ERROR: The command /home/eda/IC615/oa_v22.41.004/bin/sysname returned an error status:
                            unknown
不知是否有高手可以指点!?
GMT+8, 2025-12-26 14:05 , Processed in 0.023517 second(s), 5 queries , Gzip On, Redis On.
