在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 39503|回复: 274
经典 Class AB Rail-to-Rail OP.AMP.
发表于 2007-1-15 11:14:23 | 显示全部楼层 |阅读模式
一个经典的 Class AB Rail-to-Rail OP.AMP.
使用效果不错
OPAMP.rar
1.06 MB, 下载次数: 2873 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-1-15 11:40:15 | 显示全部楼层
不错的reference , thank you
发表于 2007-1-15 13:00:19 | 显示全部楼层
看了再说!!
发表于 2007-1-15 13:03:16 | 显示全部楼层
Abstract— This paper presents a two-stage, compact, powerefficient
3 V CMOS operational ampiifier with rail-to-rail input
and output ranges. Because of its small dle area of 0.04 mmz, it is
very suitable as a VLSI library cell, The floatlng class-AB control
is shifted into the summing circuit, which results in a noise and
offset of the amplifier wh]ch are comparable to that of a three
stage amplifier. A floating current source biases the combined
summing circuit and the class-AB control. This current source
has the same structure as the class-AB control which provides a
power-supply-independent quiescent current. Using the compact
architecture, a 2.6 MHz amplifier with Miller compensation and
a 6.4 MHz amplifier with cascoded-Miller compensation has been
realized. The opamps have, respectively, a bandwidth-to-supplypower
ratio of 4 MHz/mW and 11 MHz/mW for a capacitive
load of 10 pF.
发表于 2007-1-15 13:04:46 | 显示全部楼层
1994的IEEE
A Compact Power-Efficient 3 V CMOS
Rail-to-Rail Input/Output Operational
Amplifier for VLSI Cell Libraries
发表于 2007-1-15 13:21:16 | 显示全部楼层
看了再说!!
发表于 2007-1-15 13:45:28 | 显示全部楼层
楼主多谢分享
发表于 2007-1-15 23:31:17 | 显示全部楼层
要不要钱的说
发表于 2007-1-15 23:33:15 | 显示全部楼层
狠狠心下了,希望没上当
发表于 2007-1-17 10:09:52 | 显示全部楼层
class AB opamp俺也作国
不只这个会不会更好点
GMT+8, 2024-4-27 03:18 , Processed in 0.028845 second(s), 8 queries , Gzip On, Redis On.
