在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 22002|回复: 28
Iscape04.21启动报libXext.so.6找不到
发表于 2013-5-10 22:53:29 | 显示全部楼层 |阅读模式
在启动Iscape04.21时报错,提示libXext.so.6找不到, 报告如下。
但事实上libXext.so.6在如下路径:
/usr/X11R6/lib64/libXext.so.6
大侠指教一下是怎么回事??非常着急中...
[url=mailto:xx@local[/tools/cadence/iscape/IScape04.21-p004lnx86]57%]xx@local[/tools/cadence/iscape/IScape04.21-p004lnx86]57%[/url] ./iscape/bin/iscape.sh
Initializing InstallScape using JVM at /tools/cadence/iscape/IScape04.21-p004lnx86/iscape.04.21-p004/runtime/LNX86/bin/java. This might take some time...
Exception in thread "main" java.lang.UnsatisfiedLinkError: /tools/cadence/iscape/IScape04.21-p004lnx86/iscape.04.21-p004/runtime/LNX86/lib/i386/xawt/libmawt.so: libXext.so.6: cannot open sharedobject file: No such file or directory
        at java.lang.ClassLoader$NativeLibrary.load(Native Method)
        at java.lang.ClassLoader.loadLibrary0(Unknown Source)
        at java.lang.ClassLoader.loadLibrary(Unknown Source)
        at java.lang.Runtime.load0(Unknown Source)
        at java.lang.System.load(Unknown Source)
        at java.lang.Runtime.loadLibrary0(Unknown Source)
        at java.lang.System.loadLibrary(Unknown Source)
        at sun.security.action.LoadLibraryAction.run(Unknown Source)
        at java.security.AccessController.doPrivileged(Native Method)
        at java.awt.Toolkit.loadLibraries(Unknown Source)
        at java.awt.Toolkit.<clinit>(Unknown Source)
        at com.khanpur.installer.gui.InstallerUI.main(InstallerUI.java:107)
 楼主| 发表于 2013-5-10 23:13:24 | 显示全部楼层
盼望指导中...
急着用。
发表于 2013-5-10 23:36:15 | 显示全部楼层
you install iscape 32 bit in linux 64
you must install libXext in 32 bit pack with this command
yum install libXext.i686
发表于 2013-12-27 16:32:04 | 显示全部楼层
遇到同样的问题
发表于 2013-12-27 16:33:19 | 显示全部楼层
Initializing InstallScape using JVM at /root/Downloads/Cadence/base/SPB16.60.000_lnx86.Base/CDROM1/iscape.04.20-p001/runtime/LNX86/bin/java. This might take some time...
Exception in thread "main" java.lang.UnsatisfiedLinkError: /root/Downloads/Cadence/base/SPB16.60.000_lnx86.Base/CDROM1/iscape.04.20-p001/runtime/LNX86/lib/i386/xawt/libmawt.so: libXtst.so.6: cannot open shared object file: No such file or directory
发表于 2013-12-27 16:50:15 | 显示全部楼层
yum install glibc.i686 libXtst.i686
搞定
发表于 2014-2-13 16:59:26 | 显示全部楼层
同样没有32位的libXext.so.6这个库,在lib64下有,但是因为是32位的程序,所以没法调用,求解决办法
发表于 2014-2-25 13:09:51 | 显示全部楼层
bangding!!!!!
发表于 2014-3-2 10:58:21 | 显示全部楼层
有下载libxext的地址码?
发表于 2014-3-9 07:45:08 | 显示全部楼层
Did you install: " ksh, build-essential, open jdk-7-jre, vim, aptitude, xfonts ..., ssh-server, csh, lsb-core, libstdc++6"
1/ if not  ..... install it
sudo apt-get install ksh build-essential openjdk-7-jre vim aptitude csh ssh lsb-core libstdc++6 xfonts-100dpi xfonts-75dpi xfonts-100dpi-transcoded xfonts-75dpi-transcoded ttf-freefont
Restart the system. Now you are able to install Cadence Software
  2/ if still get same problem
edit escape.sh
      if [ "X$java_vm" = "X" ]; then
      java_vm=`FindJavaInPath`;
      fi;
with
      fi;
   java_vm=Path_to_your_java_bin_folder // in this case, /usr/lib/jvm/java-7-openjdk-     amd64/bin/java
GMT+8, 2025-5-22 00:07 , Processed in 0.030900 second(s), 8 queries , Gzip On, MemCached On.
