查看: 20313|回复: 79
并行计算机体系结构 :硬件、软件方法!
发表于 2013-1-8 12:18:04 | 显示全部楼层 |阅读模式
Parallel Computer Architecture: A Hardware/Software Approach
The most exciting development in parallel computer architecture is the convergence of traditionally disparate approaches on a common machine structure. This book explains the forces behind this convergence of shared-memory, message-passing, data parallel, and data-driven computing architectures. It then examines the design issues that are critical to all parallel architecture across the full range of modern design, covering data access, communication performance, coordination of cooperative work, and correct implementation of useful semantics. It not only describes the hardware and software techniques for addressing each of these issues but also explores how these techniques interact in the same system. Examining architecture from an application-driven perspective, it provides comprehensive discussions of parallel programming for high performance and of workload-driven evaluation, based on understanding hardware-software interactions.
Features:
  • synthesizes a decade of research and development for practicing engineers, graduate students, and researchers in parallel computer architecture, system software, and applications development
  • presents in-depth application case studies from computer graphics, computational science and engineering, and data mining to demonstrate sound quantitative evaluation of design trade-offs
  • describes the process of programming for performance, including both the architecture-independent and architecture-dependent aspects, with examples and case-studies
  • illustrates bus-based and network-based parallel systems with case studies of more than a dozen important commercial designs
About the AuthorDavid Culler led the Berkeley Network of Workstations (NOW) project, which sparked the current commercial revolution in high-performance clusters. Anoop Gupta co-led the Stanford DASH multiprocessor project, which developed the shared-memory technology increasingly used in commercial machines.
Jaswinder Pal Singh led the development of the SPLASH and SPLASH-2 suites of parallel programs, which have defined the workloads and methodology used to drive decisions and evaluate trade-offs in shared- memory parallel architecture.
Parallel Computer Architecture - A Hardware Software Approach.pdf
5.3 MB, 下载次数: 1101 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2013-1-8 20:44:33 | 显示全部楼层
领域好书
发表于 2013-1-10 00:13:47 | 显示全部楼层
这本书真的是97年出版的??
发表于 2013-1-13 01:10:52 | 显示全部楼层
这本书非常不错啊!强烈推荐
发表于 2013-1-13 20:47:03 | 显示全部楼层
支持楼主。。。
发表于 2013-1-15 21:50:33 | 显示全部楼层
good book
发表于 2013-1-17 10:20:57 | 显示全部楼层
总之谢谢楼主分享了:)
comp arch的书还是很需要的
发表于 2013-1-18 23:00:02 | 显示全部楼层
学习学习
发表于 2013-1-24 20:59:57 | 显示全部楼层
谢谢,书非常好!!
发表于 2013-1-29 16:21:14 | 显示全部楼层
经典之作 谢谢分享
GMT+8, 2025-9-24 21:55 , Processed in 1.297773 second(s), 7 queries , Gzip On, Redis On.
