在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 1461|回复: 0
[资料] MSP430F449与24C01通讯程序
发表于 2012-11-1 21:27:28 | 显示全部楼层 |阅读模式
MSP430F449与24C01通讯程序 调试成功
#include "msp430x44x.h"
//P4.7  SDA
//P4.6  SCL
#define SDA_0  (P4DIR|=BIT7)
#define SDA_1  (P4DIR&=~BIT7)
#define SCL_0  (P4DIR|=BIT6)
#define SCL_1  (P4DIR&=~BIT6)
#define DIR_OUT  (P4DIR|=BIT7)
#define DIR_IN   (P4DIR&=~BIT7)
void Delay(unsigned int n);
void Start(void);
void Stop(void);
void Send_Byte(unsigned char data);
unsigned char Receive_Byte(void);
void Ack(void);
void I2C_ACK(unsigned char tm);
void Send_word(void);
void Receive_word(void);
unsigned char *D,*M,ADD,Ack_Flag;
unsigned int MPM[16];
unsigned int DDT[16]={0xf316,0x6921,0xd315,0xc523,0xb628,0x8525,0xc324,0xd716,0xf316,0x6921,0xd315,0xc523,0xb628,0x8525,0xc324,0xd716};
void main(void)
{   unsigned int i;
    WDTCTL=WDTPW+WDTHOLD;
    D=(char*)DDT;
    ADD=0;                               //24C01内数据读写首地址
    M=(char*)MPM;
    for(i=0;i<4;i++)
      {  Send_word();
         Delay(1000);
         ADD+=8;
       ADD=0;
       Receive_word();
  while(n-- > 0);
//*****************************************开始
void Start(void)
{   P4OUT&=0x3F;
    SDA_1;
    SCL_1;
    SDA_0;
    SCL_0;
//******************************************停止
void Stop(void)
{   SCL_0;
    SDA_0;
    SCL_1;
    SDA_1;
//***************************************发送一个字节
{   unsigned char BI,i;
    BI=0x80;
    for(i=0;i<8;i++)
     {  if((data&BI)==BI) SDA_1;
          else SDA_0;
        SCL_1;
        Delay(50);
        SCL_0;
        BI>>=1;
//********************************************写完一个字节判断应答
void Ack(void)
{       DIR_IN;
        SCL_1;
        Ack_Flag = 0;
        Delay(10);
        if ((P4IN & BIT7))
            Ack_Flag = 1;
        SCL_0;
        Delay(10);
//*******************************************接收一个字节
{       unsigned char i,temp=0x80,tempdata;
        tempdata=0;
        DIR_IN;
        for(i=0;i<8;i++)
            SCL_1;
            if((P4IN&BIT7)==BIT7) tempdata|=temp;
            temp>>=1;
            SCL_0;
    return(tempdata);
//************************************************接收一个字节后发送应答信号
        if(tm==0) SDA_0;
          else SDA_1;
        Delay(10);
        SCL_1;
        Delay(10);
        SCL_0;
        Delay(10);
//*************************************************发送一个数组
{   unsigned char i;
  while(1)
  {  Start();
    Delay(20);
    Send_Byte(0xA0);
    Ack();
    if (Ack_Flag) continue;
    Send_Byte(ADD);
    Ack();
    for(i=0;i<8;i++)
     Send_Byte(*D++);
     Ack();
    if (!Ack_Flag) break;
    Stop();
//************************************************接收一个数组
{   unsigned char i;
  while(1)
  {  Start();
    Send_Byte(0xA0);
    Ack();
    Send_Byte(ADD);
    Ack();
    Start();
    Send_Byte(0xA1);
    Ack();
    for(i=0;i<31;i++)
    { *M++=Receive_Byte();
      I2C_ACK(0);
    Delay(5);
    *M=Receive_Byte();
    I2C_ACK(1);
   Stop();
GMT+8, 2024-4-27 03:52 , Processed in 0.030129 second(s), 8 queries , Gzip On, Redis On.
