在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 1567|回复: 2
[原创] Golden Gate Bridge Still Shines After 75 Years
发表于 2012-6-10 18:30:19 | 显示全部楼层 |阅读模式
This is the VOA Special English Technology Report.
The Golden Gate Bridge is celebrating its seventy-fifth anniversary. The bridge opened to vehicle traffic on May twenty-eighth, nineteen thirty-seven. Since then, more than two billion vehicles have crossed the world famous structure between San Francisco and Marin County, California. As many as one hundred twelve thousand cars make the trip each day.
The Golden Gate Bridge had the longest suspension span in the world, at the time it was built. The suspended roadway stretches one thousand two hundred eighty meters between the bridge’s two tall towers. Today it still rates among the top ten longest bridge spans in existence.
Mary Currie works for the Golden Gate Bridge, Highway and Transportation District. She says the bridge is one of the most extraordinary engineering projects of all time.
MARY CURRIE: “The Golden Gate Bridge is an engineering marvel certainly, and it gets award after award after award for what it means in civil engineering and structural engineering. It’s also a place where things happen first. For example, we were the first suspension bridge to have to change the roadway deck.”
The Golden Gate Bridge is named after the Golden Gate Strait. That narrow passage of water connects the San Francisco Bay to the Pacific Ocean. Joseph Strauss was the chief engineer of the Golden Gate Bridge project. Work began in nineteen thirty-three. The project took four years to complete.
Builders at work on the Golden Gate Bridge in 1935xBuilders at work on the Golden Gate Bridge in 1935
The bridge is two thousand seven hundred eighty-eight meters long from one end to the other. It is twenty-seven meters wide. Two large cables pass over the top of the bridge’s towers. These structures stand two hundred twenty seven meters above water and one hundred fifty two meters above the road. Each cable holds more than twenty-seven thousand five hundred strands of wire.
Two hundred fifty pairs of vertical suspender ropes connect the support cables to the suspension bridge. This is part of what enables the bridge to move up and down by nearly five meters.
The Golden Gate Bridge weighed eight hundred eleven million five hundred thousand kilograms when it was completed in nineteen thirty-seven. The San Francisco Chronicle newspaper called the finished project, “a thirty-five million dollar steel harp!”
Architect Irving Morrow gets credit for the bridge’s bright orange color. The Navy wanted the bridge painted in yellow and black. The Air Force had suggested red and white.
MARY CURRIE: “But we were fortunate that Irving Morrow knew that that color would blend with the environment, it would contrast with the ocean and the air above, and it would also allow the art deco styling to really stand out.”
And that's the VOA Special English Technology Report, written by June Simms. Transcripts, MP3s and podcasts of our reports are at voaspecialenglish.com. We're also on Facebook and Twitter at VOA Learning English. I'm Steve Ember.
发表于 2015-5-21 16:59:16 | 显示全部楼层
牛头不对马嘴
发表于 2015-5-27 15:13:46 | 显示全部楼层
金门大桥。。。
GMT+8, 2024-4-27 12:40 , Processed in 0.025240 second(s), 8 queries , Gzip On, Redis On.
