在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 22216|回复: 93
[资料] 斯坦福教你设计sigma-delta ADC
发表于 2012-5-11 12:11:39 | 显示全部楼层 |阅读模式
A 1.8-V Digital-Audio Sigma-Delta Modulator in 0.8-µm CMOS .pdf (289.59 KB, 下载次数: 3472 ) 斯坦福教你设计sigma-delta  ADC
发表于 2012-5-11 14:28:35 | 显示全部楼层
学习下,谢谢
发表于 2012-5-11 14:40:02 | 显示全部楼层
学习一下  呵呵
发表于 2012-5-11 14:48:21 | 显示全部楼层
回复 1# bigniu
学习下,谢谢
Thanks for sharing!
发表于 2012-5-11 14:53:45 | 显示全部楼层
回复 4# fhchen2002
Abstract — Oversampling techniques based on sigma-delta (SD) modulation offer
numerous advantages for the realization of high-resolution analog-to-digital (A/D)
converters in a low-voltage environment. This paper examines the design and
implementation of a CMOS SD modulator for digital-audio A/D conversion that operates
from a single 1.8-V power supply. A cascaded modulator that maintains a large full-scale
input range while avoiding signal clipping at internal nodes is introduced. The experimental
modulator has been designed with fully-differential switched-capacitor integrators
employing different input and output common-mode levels and boosted clock drivers in
order to facilitate low voltage operation. Precise control of common-mode levels, high power
supply noise rejection, and low power dissipation are obtained through the use of two-stage,
class A/AB operational amplifiers. At a sampling rate of 4 MHz and an oversampling ratio
of 80, an implementation of the modulator in a 0.8-mm CMOS technology with metal-topolycide
capacitors and NMOS and PMOS threshold voltages of +0.65-V and –0.75-V,
respectively, achieves a dynamic range of 99 dB at a Nyquist conversion rate of 50 kHz. The
modulator can operate from supply voltages ranging from 1.5 V to 2.5 V, occupies an active
area of 1.5 mm2, and dissipates 2.5 mW from a 1.8-V supply.
发表于 2012-5-11 16:24:06 | 显示全部楼层
神牛妹子的stanford。
加油啦。
发表于 2012-5-11 16:43:46 | 显示全部楼层
就是1997年wooley的那篇jssc文章而已
发表于 2012-5-13 19:20:48 | 显示全部楼层
了解一下,支持楼主!
发表于 2012-5-16 16:24:28 | 显示全部楼层
3xsharing
发表于 2012-5-16 17:04:58 | 显示全部楼层
GMT+8, 2024-5-23 12:51 , Processed in 0.030011 second(s), 8 queries , Gzip On, Redis On.
